No spark need help?! - JeepForum.com
post #1 of 2 Old 08-13-2012, 06:00 PM Thread Starter
jeepcomanche88
jeepcomanche88's Avatar
First problem is I let the jeep sit for about 4 years in the middle of a project which was replacing the steering column and converting to a floor shift. Finally finished replacing the steering column and converting to the floor shift. Problem is now I'm having issues with no spark and not sure where the issue is coming from. I was wondering if anyone knew of this issue being caused from the new steering column. I've already replaced the crankshaft position sensor, checked and the distributor and cap look to be in good condition, and checked the ignition coil with a test light and got a response. Not really sure what else to check out any advice would be great.
Thanks in advance, Brock
88 comanche
5.5" rubicon express
35"x12.5" bfg mt's
d35 in the rear w/ detroit tru track and 4.10 gears
photos here
jeepcomanche88 is offline
post #2 of 2 Old 08-14-2012, 06:06 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Test the cPS even though it's new.
Renix CPS Testing and Adjusting
Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark.
Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad.
The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark.
Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected.
You should get a reading of .5 AC volts.
If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer.
Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off.
A little trick for increasing the output of your CPS is to drill out the upper mounting hole, or slot it so the CPS bracket rests on the bell housing when pushed down. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts.
Revised 07-30-2012
cruiser54 is offline
replaced spark plugs - 4.0 wont hold idle - 00-01 spark coil rail ahuf XJ Cherokee Technical Forum 19 01-02-2011 10:15 AM
no spark ga2001532 MJ Comanche Technical Forum 3 03-29-2010 08:39 PM
4.0l still no spark bearpaw XJ Cherokee Technical Forum 19 10-04-2009 06:48 AM
No Fuel at rail but had spark, replaced pump, has gas, no spark. wtf? Element96x XJ Cherokee Technical Forum 2 03-28-2009 05:11 AM
HELP no spark 882drxjwheeler XJ Cherokee Technical Forum 10 03-31-2005 10:29 AM
