No Heat - JeepForum.com
post #1 of 7 Old 07-22-2013, 10:52 PM Thread Starter
hakukamana
No Heat
Just picked up a 90' MJ base 4.0 AX15 NP231, had not run in a while. Got it started. No heat coming out of the heater controls. Looks like it was converted to a open system, radiator has a cap and a overflow bottle that is zip tied to the AC delete bracket. The blower motor works, the heater controls work somewhat, I can get vent air blower on, I can get defrost air blower on, appears that there is no floor air coming out of the black box with two square holes. Looked at the heater hoses, there is a valve spliced into one that has a valve in it but not connected to anything to control it. I am going to flush and install a new thermostat, the bad thing about the truck is it has idiot lights no gauges. So I can't tell anything, it doesn't even have a tach.
93 YJ 5.2L Magnum, Custom rear bumper & swing out tire carrier, Ford Explorer electric seats, Ford 8.8, TW DS, SYE, NV231D, Autometer gauges, Rhinolined interior,Bushwacker flares, LED Lighting all around, MT Classic II, BFG 32/11.50/15, Warrior Body Armour, ZJ PV, DD BB, 52mm TB, Ford 23# Injectors, HS 1.7 RR, KC lights, RE Xpress 4" lift
hakukamana is offline
post #2 of 7 Old 07-24-2013, 09:37 AM
79chiefs
1988 XJ Cherokee
Can you move the valve by hand?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 7 Old 07-24-2013, 11:17 AM Thread Starter
hakukamana
Yes I can move the valve by hand it has a flow arrow on the body and I have moved the lever in the direction of the arrow no difference. I read some where that you can remove the valve because it really dose not do anything. It should be vacumn controlled but it doesn't have a port on the valve, it looks like it was cable controlled.
post #4 of 7 Old 07-24-2013, 11:32 AM
79chiefs
1988 XJ Cherokee
What about a clogged heater core? If it sat with the valve closed it could have clogged the core.
95 E34 540i-DD
79chiefs is offline
post #5 of 7 Old 07-24-2013, 12:29 PM
dkroll
1988 MJ Comanche
bypass the core and see if the hoses get hot to see if the core is the issue. Then the valve if needed. This will isolate a blockage.
Doug
dkroll is offline
post #6 of 7 Old 07-25-2013, 08:02 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes. Ditch the valve.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #7 of 7 Old 07-26-2013, 11:14 AM Thread Starter
hakukamana
Update-OK, went through the entire system. Vacumn hoses brittle and leaking, thus the blower controls won't work correctly. (Fixed) Removed the thermostat, what a mess, it appears someone used something to stop a leak. I found what looked like hardened foam in the thermostat housing, started to clean it out and found a hole about the size of a pick in the housing.(Fixed) Replaced housing, new 180 thermostat & gasket. Before I put it all back together, complete flush, then back flush, pulled the heater control valve in the heater hoses, installed new heater hoses. Flushed heater core. 50/50 Antifreeze. (Fixed) Looks better, runs @ 180* on the money, verified with (DRBII Modis Scanner) no gauges, and the controls work the way they were supposed to run. I still can not find the heater valve control cable, and the black & white vacumn lines are repaired, black to the vacumn resv. The white I just installed a check valve.
