Quantcast No air coming from vents at all!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > No air coming from vents at all!!
Old 11-16-2009, 11:29 AM   #1
jeepin16
i have a 87 jeep comanche no ac and no matter what seting i put my heater on it wont blow any air at all from any vent!! any ideas?
jeepin16 is offline   Reply With Quote
Old 11-17-2009, 12:32 AM   #2
Pete M
1988 MJ Comanche
not even from the windshield vents?
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote
Old 11-17-2009, 11:08 AM   #3
Spokes
mine was the same way. check ur flapper valve. i just wiggled mine a little and it worked. it blew air but the heater core was bad so it was kinda pointless lol... it was a long winter.
60Th Ann. Ed. Wheels For Sale Mint Condition! PM Me!
http://newjersey.craigslist.org/pts/2813005727.html2000
Red XJ, lifted with tiny tires... for now
Build --> http://www.jeepforum.com/forum/f177/better-redder-build-thread-1280981/
Spokes is offline   Reply With Quote
Old 11-17-2009, 09:21 PM   #4
ComancheKid45
1988 MJ Comanche
installed a CD player recently?
88 Comanche, "The Blue Truck"
89 Comanche Pioneer, "Dads Wood Truck"
90 Comanche Eliminator, soon to be dubbed "Walker"
96 XJ Country, "The Road Warrior"
XC Yamaha Raptor 700r
45 Forever, Ride Proud!!
ComancheKid45 is offline   Reply With Quote
Old 11-17-2009, 10:20 PM   #5
jeepin16
no it doesnt even blow on defrost. It used to only blow on defrost but i found a vacume leak so than it worked but than i left it sit for a couple months now there is no air blowing from anywhere. I just installed a new radiator if that would have anything to do with it. and no i havent installed a cd player recently.
Old 11-17-2009, 10:23 PM   #6
jeepin16
Wheres the flapper valve located??
Old 11-18-2009, 09:13 AM   #7
ComancheKid45
1988 MJ Comanche
It sounds like you have no power to the Blower and also no power to the flapper valves........id pull the controll assembly and make sure the plug is still connected properly...also check the blower fuse under the dash
Old 11-18-2009, 11:27 AM   #8
jeepin16
ok thanks il try all those and see what happens
Old 11-18-2009, 03:22 PM   #9
jeepin16
i fugured out it was the blower fuse but now it seems to just be blowing cold air..I just replaced the radiator could that have to do with anything? maby the thermostat?
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of! OllllO
Old 11-20-2009, 07:16 PM   #10
ComancheKid45
1988 MJ Comanche
Does it ever get warm/hot after running awhile.....if it takes awhile than likely your thermostat needs replaced, also you heater core may be plugged, that can easly be flushed as well.
Old 11-22-2009, 09:30 PM   #11
jeepin16
Iv had it running for about 10 min and its still cold air coming out. Maby il try running it longer to see if it is ther thermostat and if that doesnt work il take out the heater core and clean in out.
Old 11-29-2009, 12:33 AM   #12
carnuck
1984 J-Series Truck
Could be the vacuum valve on the heater (under the hood) isn't getting vacuum to open it?
carnuck is offline   Reply With Quote
Old 11-29-2009, 08:46 AM   #13
cruiser54
1990 MJ Comanche
There is a water flow valve in the engine compartment in the heater hose. They tend to stick shut. Either replace it if you have vacuum there or open it manually and plug the vac line for the winter.
cruiser54 is offline   Reply With Quote
Glock Forum
