Newfie's MJ build , stage 1 - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > Newfie's MJ build , stage 1
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 04-05-2011, 04:02 PM   #16
newfieZJ
Yeah , I was surprise too . It was a learning experience for sure . Got the interior out . Remember that "minor repair I was talking about , see second pic
Here's how it sat inside
Here's a pic of the floor after I "wiped" if off
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 09:45 AM   #17
ZJ5point2GCL
Sorry what I am I looking at?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 10:00 AM   #18
newfieZJ
Drivers side floor board , all rusted out
I did a small patch on the pass side . It wasn't a hole , but close enough . Need to grab some rock-guard now and spray it .
Meanwhile , I'm swapping out the bucket and console from the 91 . The console is not in great shape , it cracked in 2 places . however , I may be able to use the one from the 98XJ even though it's automatic . I'd get a 'handbrake' and 2 cupholders . I hate the foot e-brake on a manual . I have seen the write-up on it and I can use the original MJ brake cable
Unread 04-07-2011, 12:35 PM   #19
newfieZJ
Got the buckets in place now . I have no carpet worthy of going back in so I guess that's going on my 'to-order' list . The inside is done for me now until I start wiring on the power windows . Things were outta hand messy in my garage so I took a few hours and cleaned things up . With the garage cleaned up , I can pull the XJ in along side the MJ and begin swapping some updated body panels . Possibly swap front diffs while it's in there . Hopefully tonite I'll have some pics of the parts on . That's my day so far
Pics to follow , cam's battery is dead , someone forgot to recharge it .
Unread 04-07-2011, 12:56 PM   #20
ZJ5point2GCL
Haha ok, I am blind then, i still don't see anything terrible, but ill take your word for it
I foot parking brake is goofy enough in an auto never mind a manual, with out it then you couldn't use your redneck limited slip
Unread 04-08-2011, 03:59 AM   #21
newfieZJ
Here's some progress pics so far
A before :
After :
A sad looking XJ :
A newer model MJ :
Unread 04-08-2011, 04:18 AM   #22
newfieZJ
The doors and hood should go on tomorrow . The XJ stuff was just laid on there and a few things adjusted . I accually had to grind off a little from the top edge on the XJ fender to close the door gap enough . Driver's side fit like a glove
Here's a few pics of the process :
You'll need to change these brackets off the XJ to attach the fenders .
Don't for get you vacumn cylider thingy , lol . It attaches to the bumper . Holes are in the XJ bumper , but , in a slightly different location . You can utilize the same location though .
MJ , naked
Once the doors and hood go on , I'm gonna rock guard the inner wheel wells , inside the flares , and the inner fender bottoms . Then , re-install the inner fender sheilds , do a final line up of the body parts and tighten everything down .
After that comes the grueling task of wiring in the front lights , power windows , and power mirrors . I have a friend for such tasks
Unread 04-09-2011, 01:33 PM   #23
newfieZJ
Now I can start the wiring process . Here's where I am now . Everything but the header is bolted down
Unread 04-09-2011, 01:36 PM   #24
newfieZJ
Here's another look at the interior , with new door panels
Yeah , it's from a 4dr so I have a few extra switches . Until I find a replacement , it will do .
Now to email my wiring guru
Unread 04-09-2011, 01:40 PM   #25
newfieZJ
Here's a few pics of the hood alignment . I took hinges and all from the XJ . Made for a super easy swap which I did alone . I simple bolted it on and closed the hood . I didn't even have to tweek the fenders . I was very pleased
Unread 04-09-2011, 02:29 PM   #26
4124x4
2005 WK
Looks good , I'm amazed how well the body lines match. Guess i need to source a xj now. The kid that i bought my mj off of just did the 97+ grill; It doesn't look bad but bothers me, plus full sized windows and mirrors would be nice...
did you/can you swap the lock cylinders? (or ignition/glovebox for single key?)
keyless entry/central locking?
4124x4 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2011, 03:25 PM   #27
newfieZJ
I have yet to check to see if the lock cylinders can be swapped . I can live with a spare key , but ,, it would be nice .
The wiring is yet to be started , but , it all must operate . I have the XJ to follow for the wires . Doubt it will get keyless entry .
Body lines came out great , when it does get paint , you won't see anything . I've even tweeked the pass fender after seeing the pic above , lol . It's flush now
I also just installed the center console from the XJ . Got a decent fit , and it's bolted down . I took the auto shifter plate and remover the center . Then , installed the boot in it and it looks great . Ahhh yes , cup holders , very important to a coffee addict , lol . Pics later .
Unread 04-10-2011, 11:55 PM   #28
rogerhill
I wish I had a MJ in my jeep stable. They are BadA**
rogerhill is offline   Reply With Quote Quick reply to this message
Unread 04-10-2011, 11:58 PM   #29
ZJ5point2GCL
looking good, its coming together pretty fast, do you have plans on putting the newer dash in? if even possible?
Unread 04-11-2011, 03:38 AM   #30
newfieZJ
I kinda wanna do the dash install , but I have a feeling , that's coming in stage 2 . It's definately doable but it means a full wiring and powertrain swap .
I figure I'll drive it for a while and see if I like it first . The XJ is going under a tarp today , sored parts
Here's some pics of the console
