new to comanche's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > new to comanche's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 03-22-2012, 07:46 PM   #1
ZJ_flexxxer
1994 ZJ
new to comanche's
ok so i'm planning on buying this sweet little comanche for $1100, it's 4cyl 4speed with a little over 200k on it. i didn't really see any rust on it and it seems to be in decent shape besides the fact that someone painted it flat black.
it's 2wd and i of course want to do the 4wd swap in time but for now i just want it to be a daily driver.
i'm also really interested in swapping to a 97+ front end.
any tips/suggestions i would like to hear. i can't wait to get this thing
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's [URL="http://www.jeepforum.com/forum/f197/project-la-re-do-rebuild-thread-1212129/"][COLOR="Blue"]BUILD THREAD[/COLOR][/URL]
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress [URL="http://www.jeepforum.com/forum/f53/zj_flexxxers-manche-build-1349142/"][COLOR="Blue"]BUILD THREAD[/COLOR][/URL]
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
[URL="http://www.youtube.com/user/DirtHicksVideos"][COLOR="Red"][FONT="Showcard Gothic"][U][SIZE="5"]SUBSCRIBE TO MY YOUTUBE CHANNEL![/SIZE][/U][/FONT][/COLOR][/URL]
ZJ_flexxxer is offline   Reply With Quote Quick reply to this message
Unread 03-22-2012, 08:57 PM   #2
Madeoflite
Check the floor boards
Madeoflite is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 11:47 PM   #3
ftpiercecracker
1990 MJ Comanche
1. drive it BEFORE you buy it
2. does everything work?
3. how does it shift?
4. check for frame rust
5. throughly check the engine bay for leaks (oil, coolant, etc) if it looks too clean, the guy might be trying to hide somethin
6. if he says he wants 1100, offer him 950 CASH, people love the green.
and if your gonna swap in a 4wd you might as well swap in an ax-15 tranny as well, just for good measure.
good luck
ftpiercecracker is offline   Reply With Quote Quick reply to this message
Unread 03-25-2012, 06:54 AM   #4
97_4popper
1990 MJ Comanche
Also, check for clutch master and slave cylinder leakage.
Get a donor. Much easier than trying to piece it together.
I'm amazed at all the stuff I continue to pull from the donor.
Good Luck with it.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
http://img.photobucket.com/albums/v1...IMG_0101-2.jpg
Check out comancheclub.com...
My build thread: http://comancheclub.com/forums/viewt...hp?f=7&t=27756
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 06:32 PM   #5
ZJ_flexxxer
1994 ZJ
thanks for the advice guys. i'm still waiting on the guy to buy his new car before i get this thing. so right now it's still kinda up in the air, i'm keeping my fingers crossed because i've always wanted a 'manche
