new to comanche's - JeepForum.com
post #1 of 5 Old 03-22-2012, 06:46 PM Thread Starter
ZJ_flexxxer
1994 ZJ
new to comanche's
ok so i'm planning on buying this sweet little comanche for $1100, it's 4cyl 4speed with a little over 200k on it. i didn't really see any rust on it and it seems to be in decent shape besides the fact that someone painted it flat black.
it's 2wd and i of course want to do the 4wd swap in time but for now i just want it to be a daily driver.
i'm also really interested in swapping to a 97+ front end.
any tips/suggestions i would like to hear. i can't wait to get this thing
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
ZJ_flexxxer is offline
post #2 of 5 Old 03-22-2012, 07:57 PM
Madeoflite
Check the floor boards
Madeoflite is offline
post #3 of 5 Old 03-24-2012, 10:47 PM
ftpiercecracker
1990 MJ Comanche
1. drive it BEFORE you buy it
2. does everything work?
3. how does it shift?
4. check for frame rust
5. throughly check the engine bay for leaks (oil, coolant, etc) if it looks too clean, the guy might be trying to hide somethin
6. if he says he wants 1100, offer him 950 CASH, people love the green.
and if your gonna swap in a 4wd you might as well swap in an ax-15 tranny as well, just for good measure.
good luck
ftpiercecracker is offline
post #4 of 5 Old 03-25-2012, 05:54 AM
97_4popper
Also, check for clutch master and slave cylinder leakage.
Get a donor. Much easier than trying to piece it together.
I'm amazed at all the stuff I continue to pull from the donor.
Good Luck with it.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #5 of 5 Old 03-26-2012, 05:32 PM Thread Starter
ZJ_flexxxer
1994 ZJ
thanks for the advice guys. i'm still waiting on the guy to buy his new car before i get this thing. so right now it's still kinda up in the air, i'm keeping my fingers crossed because i've always wanted a 'manche
Comanche's normally hard to find? FleshEater MJ Comanche Technical Forum 19 06-21-2011 02:40 PM
new to comanche's 94xj-86mj MJ Comanche Technical Forum 1 04-08-2010 08:01 AM
Comanche's are tough(er than XJ's)... [VIDEO] SoloCamo XJ/MJ Cherokee Non-Technical Forum 7 06-20-2008 12:07 AM
Gas mixing in with oil in both of my Comanche's TerraWombat MJ Comanche Technical Forum 12 07-21-2005 06:07 AM
Comanche's First Dent BACKROAD MJ Comanche Technical Forum 5 05-10-2005 08:55 PM
