Neutral safety switch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Neutral safety switch
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 08-29-2005, 12:43 PM   #1
cj7xjmj
Well, my neutral safety switch went bad in my trail rig This was not unexpected, it has been acting up from time to time. I was wondering if anyone has tried to repair/rebuild these devices, or can tell me how to test what part is bad and replace it. I really cant see spending t5he kind of money they want for the switch (200), that could be my new BTF kryptonite diff cover, for my 8.8. Or if some one knows how to bypass this device, it would be greatly appreciated. Tis is my trail rig.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
[url]http://independent4x.com/generic67.html[/url]
[url]http://community.webshots.com/user/cj7xjmj[/url]
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline   Reply With Quote
Unread 08-29-2005, 01:43 PM   #2
cincyjeeprs
Check the pin-outs at the connector up high on the firewall before you bother trying to take it off. It's a PITA.
The connector terminals labeled 'B' and 'C' should have continuity in park and neutral, 'A' and 'E' in reverse, 'A' and 'G' in 3rd, and 'A' and 'H' in the 1st-2nd position.
Then, if it is really bad (not that I doubt you), go to jeepin.com for the removal & cleaning info.
cincyjeeprs is offline   Reply With Quote
Unread 08-30-2005, 07:19 AM   #3
cj7xjmj
Thanks for the info, on how to test it. The symptoms I am haivng are a no crank, when in park, but if I wiggle the shifter in nuetral, or move it, it starts. Then some times it doesnt. Battery fully charged, gas tank full of fuel. Those are the reasons why I suspect the NSS, instead of some other sensor.
Unread 08-31-2005, 05:05 PM   #4
RuggedJeep
http://jeepin.com/features/nss/index.asp
97XJ D30/Truhi9, Alloys, 36's, Beadlocked, Caged.
RuggedJeep is offline   Reply With Quote
