need a part# - JeepForum.com
post #1 of 6 Old 02-12-2013, 04:36 PM Thread Starter
54bobby
need a part#
i need the rubber (L shaped) elbow fitting that sits in the valve cover and attaches to a breather hose that goes to the air cleaner. it's a 87 2.5. the valve cover has 3 openings. oil fill is first, then right behind it, the piece i need and then another in the rear. please help as the dealer can't. the rubber is torn and it's blowing oil out.
54bobby is offline
post #2 of 6 Old 02-12-2013, 05:34 PM
mj40
1989 MJ Comanche
this stuff....aftermarket..
http://www.4wd.com/Jeep-Engine-Perfo...pn=JEP53006238
mj40 is offline
post #3 of 6 Old 02-12-2013, 08:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by mj40 View Post
Except he's got an 87 and that's for 91 and later.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 6 Old 02-13-2013, 02:38 AM Thread Starter
54bobby
that looks close but the site wont open up. i'll try a little later. is that stuff nla? i've been scouring the web with no luck. if possible, i'd like to keep her original before piecing together hoses.
54bobby is offline
post #5 of 6 Old 02-13-2013, 04:44 AM
mj40
1989 MJ Comanche
seems 87 is a cross over year... can your get a picture of the fitting/rubber piece your looking for.... i've found pcv parts for 86 and for 88 up.....
mj40 is offline
post #6 of 6 Old 02-22-2013, 10:41 PM
carnuck
1984 J-Series Truck
Look on the "HELP!" rack at the parts store. Lots of that stuff on there. NAPA used to carry the vacuum setup (2 separate pieces) in the Ballkamp book. IIRC it was a 715-XXX number
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
