Need Engine identification help!
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Hello,
I own a 1989 Comanche with a tired engine. I found a person on the net who has a "Jeep engine" which is a line six and is fuel injected. He is not able to tell me any information of what jeep it has came out of. My question is: How can I tell the difference between a 4.0 L engine and a 4.0 L (H.O.)engine? Are there physical differences or are there specific Numbers to look on the block? Can I make a 4.0L HO work in my truck without doing too much to swap it (such as the wire harness)? Any info anybody has that will help me with this purchase would help a bunch! Thank you! Dkroll
#2 |
I believe you should look for vacuum lines, I think in 1991 they switched from Renix 4.0L (which you have now) to the HO. Also the intake ports on the HO heads are higher on the HO. And I believe you would have to swap the ECU and header....
[URL="http://jeepicon.com"][CENTER][SIZE="5"][FONT="Century Gothic"][COLOR="Yellow"]jeepicon.com[/COLOR][/FONT][/SIZE][/CENTER][/URL] [FONT="Century Gothic"][CENTER][URL=http://jeepicon.com][COLOR="Yellow"]Jeep Forum and Gallery[/COLOR][/url][/CENTER][/FONT] |
#3 |
Have him look for the casting numbers on the block and cylinder head. Then post them up here.
#4 |
If im not mistaken the Renix was TBI(throttle body injection) and the HO is MPI(Multi-port injection). that may be how you can tell.
#5 |
#6 |
Oh ok. my bad.
#7 |
Renix 4.0s tend to have a silver valve cover, HOs tend to have a black valve cover.
Jeep on! --Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc. Also an 86 MJ Metric ton and 2 '90 MJs Projects/wheelin' pics: picturetrail.com/petermontie My email: petermontie@hotmail.com ComancheClub.com/forums |
#8 |
Thank you for the info. I found a H.O. and compared it to mine. The intake ports seemed a little higher and I noticed that my Remix has a shroud plate over the manifolds and the H.O. did not. That was the only thing that was different that I could see.
Wish I could find a 91 or 92 Eliminator with a ruff bed as a donor for my parts truck. |
#9 | |
![]() Well if I ever repaint my valve cover again (currently painted black) it's going back to silver
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2 Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors Suspension: Gabriel VST Shocks Tires: Firestone "Firehawk Indy 500" 235/70/15's |
#10 |
If the manifold is still on it, the Renix has an EGR and the HO doesn't.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
