Name that part??? - JeepForum.com
post #1 of 6 Old 10-12-2012, 04:35 PM Thread Starter
blbirgfeld
Name that part???
I have an 1986 Comanche Custom. Does anyone know what this part is? All my heater hoses go to it the it goes to my heater core.
blbirgfeld is offline
post #2 of 6 Old 10-12-2012, 06:29 PM
JeepComanche89
1989 MJ Comanche
It allows the coolant to pass through the heater core when heat is wanted, and block it from the core when you want air. I dnt know the name of it though
JeepComanche89 is offline
post #3 of 6 Old 10-12-2012, 07:49 PM
mj40
1989 MJ Comanche
heater control valve...for 2.5l....lol.....dont let it rot out..
http://www.autopartswarehouse.com/de...QQFS74705.html
mj40 is offline
post #4 of 6 Old 10-12-2012, 10:50 PM Thread Starter
blbirgfeld
is there any way to by pass this at all? i think mine is bad. i have no heat.
post #5 of 6 Old 10-13-2012, 05:20 AM
mj40
1989 MJ Comanche
2 main heater hose's one from the water pump and one return to the engine...
so yes you could remove it, some have homemade valve setup too from the local hardware store...
does the valve work, are you getting vacuum on the main supply to the heater controls in the dash then out to the valve??? i edited the pic to help abit..
mj40 is offline
post #6 of 6 Old 10-14-2012, 06:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
They stick shut. I had good luck removing it and cleaning it. The metal ones like yours are pretty hearty.
cruiser54 is offline
