My MJ - JeepForum.com
post #1 of 6 Old 04-16-2008, 03:10 PM Thread Starter
Grand Fan 4eva
My MJ
here's my DD, traded a snowmobile for it back when it was bone stock and it's only got 120k on it. '91 LWB MJ- 4.0, AW4, 31's, HiCountry tow hooks, custom back rack, tool box, full skids and floor grates for hood vents. I've got pretty much everything together to lift it 3" and i've got some 4.10's i'll be swapping in. i'd really like to go SOA 5"+ with 35's and a flat bed but then i'll be right back where i started with no real DD. i've also been thinking about a SB 350/5-speed swap with stacks but that won't happen for a while.
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #2 of 6 Old 04-16-2008, 11:19 PM
Mr_Random
1986 XJ Cherokee
Ah, I love MJ's!
I've been looking around for some for sale, but sadly the only one I can find is pretty bad...
I want yours... with a manual though... but anyways, looking great!
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #3 of 6 Old 04-16-2008, 11:38 PM
jage
Really? I'm exactly the opposite I need an Auto and keep finding sticks.
When you're lookin there aren't any.
00 Jeep TJ Body Armor Rear+Rails Hanson Front 12K Winch 4" Full Traction LA 35" Toyo Open Country Mud Atlas II Finally!
<- mi crappy blog | Because Jeep doesn't make a van ->
Don't buy Rusty's <- Still hating after all these years -> Don't buy Rusty's
jage is offline
post #4 of 6 Old 04-17-2008, 12:15 AM
Mr_Random
1986 XJ Cherokee
Why do you want auto? Please don't say you can't drive stick!!
I learned at sixteen, and have since felt that auto's are boring and make me feel out of tune with the vehicle...
oh, and floor grates for hood vents... sounds hillbilly, but functional! I'll think about that... It looks good anyways!
Jeepus buildicus:
post #5 of 6 Old 04-17-2008, 09:17 AM
jage
I need an auto because it is for my wife and the F250 is crew+longbed which makes it a bit rough to park.
PS. You know you can fix your 4wd problem with a small hose clamp don't you?
jage is offline
post #6 of 6 Old 04-17-2008, 09:39 AM Thread Starter
Grand Fan 4eva
i like having the auto because my xj is a 5-speed so i get one of each plus, the MJ has the "power" switch for the tranny which changes the shift points and make it even more fun! i love driving this truck, especially when i can burn both rear tires through second gear without much trouble i do feel bad beating on it though with only 120k... and i'm not sure whose 4wd problem you're talking about but i tried everything short of a new vacuum motor and ended up locking mine. i used a heavy duty spring and left the motor shaft free so the 4wd light is still functional on the dash.
'91 MJ
'68 M715
'98 5.9 Limited
