My first comanche and sloow build - Page 2 - JeepForum.com
post #16 of 26 Old 01-20-2013, 06:01 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Starting to clean up the motor one side at a time, Got the intake and exhaust manifold pulled ( to my suprise all the bolts came out very easy )
Knew the exhaust manifold was cracked and prevously welded a few times
Time for an upgrade, picked up some pacesetter headers off ebay a few months back for $147.50 shipped
Quick coat of paint since they had some paint chips from being moved around. ( also painted the motor mount )
Cleaned and painted the intake manifold and heat shield
Block after a cleaning and some paint
Throttle cable bracket cleaned and painted as well
Painted the bolts and will have to swap the washers with the new ones that came with the headers ( forgot all about them till i called it a day )
Shinned up the brass fittings with a wire wheel
Exhaust mocked up
All assembled
Hopefully i can find a good egr tomarrow from the jy, Apparently the egr tube needs to be modified to fit the headers, its off by a solid 5/8 and need to get the one bolt in behind tube 4. Think i will try to grind it down some
Previous total - $1365
Headers $147.50
Cost to date- $1512.50
1995 xj dd
1990 comanche 4.0 auto 4wd
http://comancheclub.com/topic/36077-...e-runs45-lift/
PaRtS 4 SaLe
NIB xj rear air ride suspension
NOS 5.9 shifter handle
4 1995 orvis doors with panels
5.9 rockers
5.9 roof rack
italiang4lif89 is offline
post #17 of 26 Old 01-20-2013, 06:18 PM
Rican142
Wow, the motor looks great dude
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #18 of 26 Old 01-21-2013, 07:46 AM Thread Starter
italiang4lif89
1990 MJ Comanche
Thanks still have a ways to go, just need some time and the brown santa to come lol
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #19 of 26 Old 01-21-2013, 08:36 AM
Rican142
Ohh I know lol and brown santa?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #20 of 26 Old 01-21-2013, 04:10 PM
JeepComanche89
1989 MJ Comanche
Not to highjack a build thread, expecially an mj, but i would appreciate it if you would respond to my pm. Thanks
JeepComanche89 is offline
post #21 of 26 Old 01-21-2013, 07:43 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Brown Santa is the ups man lol
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #22 of 26 Old 01-24-2013, 07:17 AM
Rican142
Hahaha thats great i can't wait to see my ups guy so i can call him that hahaha
1964 Ford F-100 1989 Jeep Comanche 1997 Jeep Wrangler
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #23 of 26 Old 01-30-2013, 07:13 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Had another good weekend on the comanche and made some more progress on the engine
Pulled some accessories off the front
Did not take too many before pictures, but here are some of the almost finished product
New Waterpump and painted pullys
Upgraded the fan clutch with one from a 98 ZJ and painted the fan
New high flow thermostate housing and 180 degree stat
Cleaned and painted the a/c compressor and brackets
Picked up a new to me valve cover from work, Nice upgrade
Upgraded the oil temperature sensor for when i do the gauge cluster swap
Front assembled
Changed the plugs and wires and they sent me the wrong cap and rotor :fs1:
Not too bad for a few hours of work
Still need to swap injectors
Add a second coat of paint to the valve cover and install
Wait for the brown santa to bring me alternator
Order a new cap and rotor
Change oil pan gasket and paint/clean
decide what to do with my throttle body ( really want to add the h.o one )
Swap in water temp sensor for futue gauge swap
I know I'm forgetting a few other items on the to-do list
If theres anything else i should swap out or upgrade feel free to chime in
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #24 of 26 Old 01-30-2013, 08:04 PM
JeepComanche89
1989 MJ Comanche
looking good, do you still want my stuff?
post #25 of 26 Old 03-14-2013, 08:33 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Sorry I haven't updated this in awhile, I have more a lot of progress since my last post, just a pain to update to threads constantly, more then welcome to check it out here
http://comancheclub.com/topic/36077-...oject-restore/
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #26 of 26 Old 06-09-2013, 05:59 AM
danno627
Those 'banana' leaves look like helper springs. They are only helpful when under load, which maintains the factory ride quality while the bed is empty.
danno627 is online now
