My first comanche and sloow build - JeepForum.com
post #1 of 26 Old 11-23-2012, 09:15 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Bought my first mj off of a member on comancheclub. Good fixer upper but should be a fun project
Specs
1990 comanche pioneer lwb
174k auto 4x4 355 gears
Solid frame
Newer engine with 85k
Roll bar
Needs rockers and some body work
Here are some pics
My xj in the background
Took the bench seat carpet and some trim out
What a pitta the lower seat belt bolts are
Mostly surface but has a couple poke through spots on the drivers side
Passengers side mostly surface and nothing too major
Comanche - $900
Shipping- $625 yeah i do not recomened progressive shipping in Florida :/
Cost to date- $1525
1995 xj dd
1990 comanche 4.0 auto 4wd
PaRtS 4 SaLe
NIB xj rear air ride suspension
NOS 5.9 shifter handle
4 1995 orvis doors with panels
5.9 rockers
5.9 roof rack
italiang4lif89 is offline
post #2 of 26 Old 11-24-2012, 11:40 PM
ftpiercecracker
1990 MJ Comanche
Looks like a good little project truck. Good thinking on your part, pulling the carpet as soon as you got it and all. Gotta say i really like the tire/rim combo, even if they are beaten up and all. What are your plans?
ftpiercecracker is offline
post #3 of 26 Old 11-25-2012, 12:10 AM Thread Starter
italiang4lif89
1990 MJ Comanche
Wish I would have found on before it got cold out and dark so early lol.. My plans are pretty much redo the interior with some new carpet and bucket seats
Sound system
Front end from an 97+ cherokee
Not sure about a lift yet
Have a decent amount of parts already just need the time to install lol
Pacesetter headers
Upgraded fuel injectors
New cap rotor coil and plugs
And should hopefully have the newer doors on tomorrow
Wll update with pics as progress goes
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #4 of 26 Old 11-26-2012, 03:51 PM
ftpiercecracker
1990 MJ Comanche
sounds good
post #5 of 26 Old 11-29-2012, 08:40 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Made some small progress on the mj
swapped the doors from a 99 cherrokee ( still need the door strickers )
The Donor Doors
Before
After
Another after pic, Must of delete the before pic
Still have to line up the body lines, and wire everything up but is comming along slowly
This weekend i will finish up sanding up he passengerside floor Monstaline the interior and start on fixing and doing the wiring
Anyone have a good write up on column to floo shift? The tranny is being refreshed this week and i would like to do this swap before the carpet goes in
Doors- Free from work
Cost to date - $1525
Will add in the other parts i have as i install them
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #6 of 26 Old 11-30-2012, 05:30 PM
ftpiercecracker
1990 MJ Comanche
If you havent already, get your butt over to comancheclub and sign up every question you will ever have can be answered over there. If you got power windows, have fun wiring them. While your on the interior i would HIGHLY recommend you invest the couple of bucks and buy yourself a set of these. http://www.ebay.com/itm/Jeep-Comanch...20741572395%26
Good price and direct fit, superb replacement for stock fixtures
post #7 of 26 Old 11-30-2012, 06:26 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Haha thanks and I have a build thread on there already as we'll. thanks for the recommendation. I already have them sitting in my parts pile in my room
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #8 of 26 Old 12-02-2012, 06:47 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Made some good progress on the MJ today
spotted this little jem at my work and will be working on the price with the boss, will hopefully have it at the house this weekend comming up
no rott or rust anywhere just a dent on the lower rear corner
Sold the rims/tires and front brush guard the manche came with for $160
The first 3 came off like butter, the 4th was stripped and would not come out. ending up drilling the studs to get it off
will be replacing with zj studs since i will be doing discs in the rear at some point
Got the bed off what a pitta lifting by yourself
Some 5.9 zj rims i tossed on, had left over from a part out, will use for rollers
Little present from the PO
Happy to say the frame is rott free with some flakey undercoating and minor surface rust
Misc picture of the load sesing valve, will be eliminating when i redo the brakes
Do these leafs look correct? seem kinda funny with banna shape they have
made some more progress on the passenger side floor, alot of rust but no holes bigger then a skittle lol
next weekend i will get the frame and under carriage pressure washed, and weather permitting get the monstaline rolled on
Previous total - $1525
Parts sold- $160
Cost to date- $1365
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #9 of 26 Old 12-02-2012, 07:09 PM
97_4popper
1990 MJ Comanche
springs are not correct. Maybe some sort of cheap lift spring?
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #10 of 26 Old 12-02-2012, 07:25 PM Thread Starter
italiang4lif89
1990 MJ Comanche
The truck does not look lifted, will do some more research, never seen anything like that
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #11 of 26 Old 12-03-2012, 09:20 PM
dnuccio
im subbed, interested in seeing where you go with it. my buddy and i are planning on building a comanche this summer so i may be stealing some ideas
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 26 Old 12-03-2012, 09:54 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Haha sounds good, have a lot of goodies I've been collecting before I even had the comanche, the biggest thing I need is time lol
If you have any questions as my build goes let me know I have the links for just about everything I bought for it. Headers, injectors, rad, silicon hoses, interior ect lol.
Hope you make a build thread that I can check out when the the comes
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #13 of 26 Old 12-08-2012, 09:35 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Made some small progress today on the manche, Pressue washed the frame and complete under carriage
In the process
Happy to say no rott, some minor surfac rust ( after pics )
Tomarrow will be some grinding and sanding and prep work before the monstaline goes on
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #14 of 26 Old 01-19-2013, 08:39 PM Thread Starter
italiang4lif89
1990 MJ Comanche
Been awhile since ive updated my build, Stripped the front end of its sheet metal 2 weeks ago, and Finally made some real progress last weekend and got the engine pulled, figured it would be easier to replace the exhaust manifold, motor mounts ect and paint the engine bay with the engine out the way.
First time pulling a motor and it went fairly good with a few broken items but nothing too major
Gave the engine a quick bath and who would have knew my block is blue lol
Been a little nervous putting all this time and money into this engine that i never head run since the trans was in the bed when i bought it.
Take a small edge off of things knowing it was rebuild at sometime
And the engine bay after a pressure wash
Tomarrow i will start on replacing gaskets and some engine goodies more pictures to come tomarrow
1995 xj dd
PaRtS 4 SaLe
5.9 rockers
5.9 roof rack
post #15 of 26 Old 01-19-2013, 10:47 PM
ftpiercecracker
1990 MJ Comanche
Glad to see an update, keep us posted!
