Motor Q - Page 2 - JeepForum.com
post #16 of 20 Old 10-28-2012, 06:41 AM Thread Starter
Rican142
And a spot on driver side front fender, no bigger than my hand, guy says it was from brake fluid, it makes sense
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #17 of 20 Old 10-28-2012, 08:43 AM
97_4popper
Doubtful anyone would swap a 2.5 for a 2.4.
The 2.5 is an old pushrod engine. Would look similar to a 4.0 minus 2 cylinders. The 2.4 has overhead cam. It has a cover on the front that covers the cam pulleys. Double hump kind of cover. Easy to tell apart.
Looks decent for the money.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #18 of 20 Old 10-29-2012, 08:00 AM Thread Starter
Rican142
Oh ok, thanks bud
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #19 of 20 Old 12-19-2012, 08:39 PM
greaseslapper
1987 MJ Comanche
i tried to blow up my i4 but it wouldnt die.. so instead i did a full rebuild on it and while tearing it apart i found that it had three failed cam bearings. and the rod(wrist) bearings were almost non existent. cam was shot and valves had holes. and for unexplainable reasons it still ran, granted it sounded like a diesel. i even wolered in the mud with it not haveing an oil cap. abuse....it can handle plenty of it. power none to save its live.
2.5 four wheel drive.
greaseslapper is offline
post #20 of 20 Old 12-19-2012, 09:00 PM Thread Starter
Rican142
Lol little late there buddy, but thanks for the testimony. I'm def tryin to get that jeep,
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
