More $ better Parts? - JeepForum.com
post #1 of 5 Old 05-07-2008, 08:58 AM Thread Starter
romeo_zooloo
1989 MJ Comanche
I am shopping for tie rod ends and notice that some cost $20 and others cost $65. Are the more expensive parts better/more durable than the cheaper ones? Autozone sells Duralast and Rare Parts, there are TRW parts available thru Advance I think, what is better? Please factual first-hand experiences only. Thanks for your replies. RZ
romeo_zooloo is offline
post #2 of 5 Old 05-07-2008, 09:08 AM Thread Starter
romeo_zooloo
1989 MJ Comanche
Oh, I am starting to get a vibration in the steering at about 50 mph. I bought the truck on April 9th and it has two wider size tires on the front 70's and 75's in the rear. I can't go get new tires all the way around right now and will have to make do but is it better to have the wider tires in the rear? Will TJ rims fit my 89 comanche 4wd? there is a set of stock rims with a Couple of decent tires on them around the corner and they have the Jeep insert in the center and all mine are missing.
I hit the track bar with the heal of my hand and hear a tap of metal hitting at the ball end. I am going to start with this part and move through the rest as quickly as I can afford. RZ
post #3 of 5 Old 05-07-2008, 09:51 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
TJ rims will fit your Comanche. Start replacing parts as you see that they are worn. A lot of factors play a role in wobbling, and replacing loose parts is a good first step.
88XJSport is offline
post #4 of 5 Old 05-07-2008, 10:52 PM
Pete M
1988 MJ Comanche
Don't shift into 4wd until you have matching sized tires.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #5 of 5 Old 05-08-2008, 07:19 AM
denlevi
Depends on what you want to spend. Ive purchased Azone joints in the past and never had any problems with them. They usually offer a lifetime warranty on their parts anyway, so if it wears out in a couple years it shouldnt cost you anything but your time to replace them.
denlevi is offline
Cherokee body parts - parts vehicle brianj752 XJ Cherokee Technical Forum 15 01-23-2006 11:23 AM
got some new parts... silverxj2001 XJ Cherokee Technical Forum 7 05-18-2005 06:00 PM
New Parts 4SEVEN3 XJ Cherokee Technical Forum 3 05-14-2005 10:09 PM
Illustrated Parts Breakdown or Parts Manual? Borinquenknight XJ Cherokee Technical Forum 8 11-17-2004 11:22 PM
Parts! Parts! And More Parts! It's An Emporium Of Xj Parts! Culpeper XJ Cherokee Technical Forum 15 10-19-2003 10:38 AM
