MJ is poisoning me, lol. - JeepForum.com
post #1 of 7 Old 06-04-2013, 10:17 AM Thread Starter
pingclang
1989 MJ Comanche
Hey guys, I'm new as it gets and still learning engines but I have a serious problem to address. My Comanche is feeding grey-ish smoke into the cab through the floor heat box whether the heat is on or not that smells like burning oil. I have researched this online but no one is experiencing it quite like this. I have no clue what to do here so any help from you guys is greatly appreciated.
pingclang is offline
post #2 of 7 Old 06-04-2013, 10:30 AM
SCRMBLD
There's almost no possible way oil can get in the heater box to smell like burnt oil; I doubt it's oil. BUT, the blower motor and/or resistor can be going bad and causing this burning smell. In the MJ years the resistor is usually the issue, but it may be worth replacing both while you're at it. If you don't (best case) the blower motor will stop, or (worst case) you could have an interior fire caused from the resistance of the heating/shorting out of the wires.
Here's a YouTube video of a resistor placement of what looks like a right-hand drive diesel XJ:
ΜΟΛΩΝ ΛΑΒΕ
SCRMBLD is offline
post #3 of 7 Old 06-04-2013, 10:36 AM Thread Starter
pingclang
1989 MJ Comanche
I'm sorry, I didn't word that very well. The smoke is fumes coming from the engine, not oil in the heat box. Somehow the fumes and smoke are coming through the vents. It has nothing to do with running the heat or anything. I'm still going to look into what you said though. I really appreciate you giving me something to consider.
post #4 of 7 Old 06-07-2013, 08:07 PM
Pete M
1988 MJ Comanche
The rear hood seal on my truck sucks and will allow me to "smell my engine" at certain speeds. no smoke though.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #5 of 7 Old 06-09-2013, 10:01 AM
Paradise XJ
1988 MJ Comanche
Could be an exhaust leak.
Mine had an cracked exhaust manifold and I got lots of fumes when it was hot and running hard. I also had a couple of dried out loose grommets in the firewall. Replaced (welded) manifold, replaced donut gasket. Fixed grommets. All good now
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #6 of 7 Old 07-21-2013, 11:33 PM
gus7
MJ are like women ,they love their time with you ...if they dont get it ,talk a ***** ! it maybe the blower fan burning up ......disconnect it ,pull it and smell it ....
gus7 is offline
post #7 of 7 Old 07-22-2013, 02:19 PM
dkroll
1988 MJ Comanche
Floor boards rusted out?
Doug
dkroll is offline
