MJ crossmember same as XJ? - JeepForum.com
post #1 of 6 Old 04-06-2008, 01:58 PM Thread Starter
EnderUSAF
Anyone know if the crossmember is the same from the XJ to the MJ? I currently have a long arm kit for my XJ that bolts the long arm kit up to where the XJ cross member normally is. Just curious if it will work on the MJ since my XJ's unibody is toast. I was able to pick up a free MJ from my mother in-law in cali that has no tranny, and is 2wd, so I'm gonna swap all my parts over including engine.
Combat Search and Rescue: If you go down, I'll come.
EnderUSAF is offline
post #2 of 6 Old 04-06-2008, 03:25 PM
Pete M
1988 MJ Comanche
Got pics of the kit? The MJ has the same crossmember, but there are some minor differences in the uniframe in that area. You might want to call the manufacturer and ask them (if they even know what an MJ is of course).
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 6 Old 04-06-2008, 10:23 PM Thread Starter
EnderUSAF
It's the teraflex 4" long arm lift kit. The long arm brackets bolt into where the stock crossmember on my xj does, then you drill more holes on the side of the unibody and use self tapping bolts in the side, after that you cut your stock cross member shorter and drill 2 holes in each side and they mount to the top of the long arm bracket.
post #4 of 6 Old 04-07-2008, 12:10 AM
Pete M
1988 MJ Comanche
I would call them to be sure their design is compatible. Or you can ask over at comancheclub.com/forums and see if any of the guys have the teraflex kit.
Jeep on!
--Pete
My email:
Pete M is offline
post #5 of 6 Old 04-10-2008, 08:27 PM
Grand Fan 4eva
it looks about the same to me as far as i can remember. the mj does have a fair amount of extra bracing up front compared to the xj but i think at the heart of it is the same x-member. you could probably dig up some pics on the internet and compare... i don't have it at school with me so i can't just go look, i would if i had it though. but i think they are similar enough that you wouldn't have much trouble making it work.
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #6 of 6 Old 04-11-2008, 10:13 AM Thread Starter
EnderUSAF
yeah I talked with teraflex, they said the kit will work on a man-she as well.
Crossmember Question Glazzed XJ Cherokee Technical Forum 4 02-02-2007 11:29 AM
crossmember!! fisher446 XJ Cherokee Technical Forum 7 12-21-2006 07:34 PM
crossmember studs Beeker356 XJ Cherokee Technical Forum 14 06-25-2006 09:51 PM
My tranny crossmember is... Julius4x4 XJ Cherokee Technical Forum 4 03-30-2006 11:23 PM
crossmember Qs SuperStreetJeep XJ Cherokee Technical Forum 6 03-14-2006 11:20 PM
