MJ Air Grabber - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > MJ Air Grabber
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 11-04-2014, 09:46 AM   #1
87MJ
MJ Air Grabber
While searching around for a hood scoop I came across a cheap Air Grabber scoop and wanted to know if I can mount it on my MJ hood... Anyone ever done it?
87MJ is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 02:02 PM   #2
gubachoo
depending on which style air grabber youre looking at, yeah, anything can be done but if its the one where you cut a hole in the hood to attach it, its kind of a pain. plus you have to get rid of the stock intake and figure out a place for the air filter. which one were you looking at, link?
gubachoo is offline   Reply With Quote Quick reply to this message
Unread 11-16-2014, 08:53 AM   #3
87MJ
Not sure how to attach an image here... Anyway the original air grabber like the road runner had. Cut through the hood
Unread 12-09-2014, 10:25 AM   #4
937Comanche
1991 MJ Comanche
If you mean like the 'cuda one that attaches to the engine and sticks through the hood? That would be the same as on any car. Measure where it will stick through and make sure it has enough clearance for when the air cleaner rocked with the motion of the engine. Road Runners used a variety of scoops but none were attached to just the the carb like the actual AirGrabber was. Personally unless you had an early MJ with a centered carb/TBI on a 2.8 I think it would look stupid offset like it would need to be for a 2.5 or 4.0.
'91 MJ with some mods
'14 MK without some mods
937Comanche is offline   Reply With Quote Quick reply to this message
