MJ 2wd to 4x4 conversion and just a few questions... - JeepForum.com
post #1 of 16 Old 01-07-2014, 09:54 PM Thread Starter
Caish
1987 XJ Cherokee
The sons tranny went out. Ba/5 so we looked all over and could not find a 2wd ax15.
So this week found a xj 4wd 5 speed. 1990 and it has a ax15 under it.
So we're going to convert his truck over to 4wd.
We want to use 4.5" lift from zone. The kit comes with an add a leaf for the resr.
I'm curious how much lift does a SOA give?
Would the so a yield 4.5" lift or more? If it is close I'm betting an spring spacer
Would balance it out.
In thinking also about using parts from another xj we have since it has the 3.54 gears.
Would be better with the planned 32" tires.
The other question with a short wheel base how long is the rear drive shaft,
What is the chance that an xj rear shaft will work in the MJ?
We have to go pick up the parts xj Saturday.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #2 of 16 Old 01-07-2014, 10:04 PM
Soldier905
1988 MJ Comanche
From what i have read here a XJ driveshaft wont fit a MJ so you will have to have to have yours customized . The soa give between 5-7 inchs from what has been said here .
Soldier905 is offline
post #3 of 16 Old 01-07-2014, 10:10 PM Thread Starter
Caish
1987 XJ Cherokee
Thanks. I can cut the original shaft if I have to.
Done it before was going to not have to.
Hmm SOA at say 5" would be about perfect but if it's 7 ouch.
Takes bug money to get the front that high....
Caish is offline
post #4 of 16 Old 01-07-2014, 10:21 PM
Soldier905
1988 MJ Comanche
If you do the SOA ive read also here you can possibly use a XJ front drive shaft for the rear with the use of a SYE .
post #5 of 16 Old 01-08-2014, 11:16 AM
87MJTim
1987 MJ Comanche
If you are going SOA and AAL, you will be at the 7" range. I have read on www.comancheclub.com that SOA is around 6" to 6.5".
I add 3" with new springs from General Spring (still SUA). Also, Hell Creek is making MJ springs, again. Both offer comancheclub discounts.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #6 of 16 Old 01-08-2014, 08:33 PM Thread Starter
Caish
1987 XJ Cherokee
I was not going to use the AAL if I do a spring over swap.
Thanks.
Caish is offline
post #7 of 16 Old 01-13-2014, 12:15 AM Thread Starter
Caish
1987 XJ Cherokee
Got the parts XJ home, but it did not drive the fellow replaced he head gasket but did not have the head checked, I showed up to look at it, and he pulled up it blowing steam everyone.
So out the door went my offer, and the floor boards was gone. Not normal for Arkansas.
So home it came yesterday on the car dolly with the wifes XJ towing it. My XJ does not tow well with its lift.
Today I got the tranny and transfer pulled and it have a new cat back exhaust so it came off to for my XJ.
So first hurdle is out of the way, now next weekend the conversion starts.
It will be assembled back as a 2WD ruck this time and in a month or so (when the boy saves some money) I will help him finish the conversion,
and lift.
Caish is offline
post #8 of 16 Old 01-23-2014, 05:26 PM
Ortjeepcherokee
and lift.
What about turning a wk jeep 2wd into 4wd I really wanna make it into 4wd but there's a lot of dumb people here that you ask them nice and they give you a attitude response. And all I'm asking what parts recommend to make it 4wd.
Ortjeepcherokee is offline
post #9 of 16 Old 01-23-2014, 06:37 PM
Nick05
1994 XJ Cherokee
what part of the state are you from?
Nick05 is offline
post #10 of 16 Old 01-23-2014, 06:39 PM
Ortjeepcherokee
Los Angeles but I'm moving to the state of Utah
post #11 of 16 Old 01-23-2014, 06:49 PM
Nick05
1994 XJ Cherokee
Originally Posted by Ortjeepcherokee View Post
What about turning a wk jeep 2wd into 4wd .
i am doin a little research for you, but i doubt it will be as clear cut for a wk as an xj/mj. one reason we love mj/xj's is they are extremely easy to do swaps on because chrysler is a bunch of cheap wads. however, i was askin which part of arkansas he was from.
Nick05 is offline
post #12 of 16 Old 01-23-2014, 07:00 PM
Ortjeepcherokee
But is it possible for a wk for 2wd into 4wd
post #13 of 16 Old 01-23-2014, 07:13 PM
Nick05
1994 XJ Cherokee
anything is possible with money. a conversion for a xj/mj is just a shifter for the transfer case, transfer case, 4wd tranny, front driveshaft,front axle and a little wiring. a wk has ifs, which i know can be 4wd but i am unfamiliar with. i would imagine if you could find one in a junkyard and get parts off of it, it could be done, but it might actually be easier to buy a 4wd. theoretically, you would need a transfer case, a driveshaft to run to the front, a front diff(i am assuming they are diff's), cv axles, possibly new knuckles(unsure on that). or do a sfa swap, but for that you would need to talk to somone who has done that. once again, i am no good with ifs.
Nick05 is offline
post #14 of 16 Old 01-25-2014, 03:13 AM Thread Starter
Caish
1987 XJ Cherokee
I'm in Greenbrier north of Conway.
Caish is offline
post #15 of 16 Old 01-25-2014, 03:16 AM Thread Starter
Caish
1987 XJ Cherokee
I would say you need parts from a similar year, maybe a whole car for parts.
It would be cheaper than typically trying to piece it together from a salvage yard.
Caish is offline
