milage anniversary! - JeepForum.com
post #1 of 8 Old 11-03-2008, 06:15 AM Thread Starter
Douglas
1987 MJ Comanche
milage anniversary!
Be listening! Won't be long! My 87 'manche will turn 300,000 young in less than a 1000! Yeeha! BTW, my 94 cherokee will turn 250,000 young today, Nov 3, while wife and I drive home from Kansas City! These are our only two cars!
Douglas is offline
post #2 of 8 Old 11-03-2008, 11:37 AM
Pete M
1988 MJ Comanche
Awesome. Is it still the original block and heads? Any major work done to it? How many of those miles are from while in your possession?
3 of my 4 MJs are over 200k, but none are in active daily driver service so the mileage won't get much higher anytime soon. My 97 hryser minivan (the C fell off) has 208k and still gets used, so there's hope that it'll someday get to 300k.
You should tell the guys at the Comanche Club. You might even have the record.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 8 Old 11-03-2008, 04:12 PM
Snowplow
Snowplow's Avatar
Sounds like a sticky, for a high miliage club. my 86 MJ has just hit 200000 on the 2.8 v6
Snowplow is offline
post #4 of 8 Old 11-04-2008, 08:55 AM Thread Starter
Douglas
1987 MJ Comanche
As far as I know, the comanche has the original block and heads, but rebuilt about 15,000 ago. I had the time to let it sit and the funds, and since with that many miles a 117 hp 4 popper probably was running at less that 100 hp (headwinds up hill on the interstate required full throttle), I sent it to S&S engine in Kent Washington, they give a 7 year warranty, but had them add a Delta Camshaft that's a short step up from stock in lift and duration. Put Clifford header on it, but that has been a major headache with their refusal to admit it hitting the block was their fault.
I bought in with about 240,000 on it while living in the Puget Sound area. It was native to that area. When I got it, it had "green stuff" all over the white paint, the interior was wet, and it had been used as a work truck. It had sat for a while in the back of the carlot but when I started it, no lifter or rod noise, and the clutch gave no weird noises, and all the syncro's in the 4 speed felt good. Underneath, it was a solid truck, with good paint, and no rust at all. Paid 1,100 for it. I scrubbed all the green gunk off it, pulled out all the interior and dried it out and used mildew killer on everything, have rebuilt the brakes, put a new steering gear in it, but everything else, except for the rebuilt engine, is original.
My Cherokee 4x2 we bought new. The only work to it other than normal stuff has been bearings in the differential, new radiator, starter, water pump, and crank sensor. It has the original alternator still, and on startup after an oil change, even if I forget to put oil in the oil filter, there is no rod or lifter clatter before the light goes off. Oh, yea, had to put a new headliner in. The old material came unglued.
Both have been the best autos I have ever owned.
Douglas is offline
post #5 of 8 Old 11-08-2008, 10:53 AM Thread Starter
Douglas
1987 MJ Comanche
Thought I would add this: How many of you were driving when it was common for an engine to be done for by 100,000 miles, that by 70,000 you should consider selling or trading it in because soon it would be a piece of junk?
Douglas is offline
post #6 of 8 Old 11-08-2008, 07:53 PM
Snowplow
Snowplow's Avatar
Of course we are driving now days, todays trucks are done at 50,000
Snowplow is offline
post #7 of 8 Old 11-26-2008, 08:08 AM Thread Starter
Douglas
1987 MJ Comanche
Well, it made it. Pulled into my garage last night with 300055 on the OD.
Douglas is offline
post #8 of 8 Old 11-26-2008, 05:20 PM
SoloCamo
1988 MJ Comanche
Glad to see the 4 banger hanging on with the 4.0's in the high mileage department! Congrats!
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline
'01 anniversary edition? jeepkid03 XJ/MJ Cherokee Non-Technical Forum 0 01-26-2009 06:41 PM
60th Anniversary XJ? RU55ELL XJ Cherokee Technical Forum 10 09-10-2007 07:13 AM
60th anniversary ger XJ Cherokee Technical Forum 7 10-11-2005 05:06 PM
1 Year Anniversary FitchVA XJ Cherokee Technical Forum 7 09-28-2004 08:33 AM
me and my xj's anniversary RUparrothead XJ Cherokee Technical Forum 3 03-04-2004 04:55 PM
