max tire height with stock suspension - JeepForum.com
post #1 of 5 Old 03-21-2008, 09:25 PM Thread Starter
89blkcomanche
im looking for some taller tires to replace my current 26" tall ones, what is the max tire height i can run, i have all stock suspension, ive herd a 30 or 31" is the max, i might get a 2" lift kit someday
93' ZJ 4.0l 4x4 auto, trail rig, 6 kc's, green and gray, 3.73 swap, 32x11.50 bfg mudd terrain
89' comanche, 2.5L 80k original miles, single stage paint- sold
89blkcomanche is offline
post #2 of 5 Old 03-22-2008, 07:47 PM
Pete M
1988 MJ Comanche
For a 2wd? 30" is a good as it gets. This is my 88 (back when it was a 2wd) on 30" BFGs.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 5 Old 03-22-2008, 09:10 PM Thread Starter
89blkcomanche
so like these wouldn't fit then http://seattle.craigslist.org/sno/pts/614964126.html
post #4 of 5 Old 03-23-2008, 07:47 AM
Pete M
1988 MJ Comanche
Not on a 2wd. And not on a 4wd (which are 1" taller than 2wds) with the aftermarket rims. The only way to run 31s on aftermarket rims is a full 3" lift (and even then some combinations of tire/wheel can cause issues). Some brands of 31 (not all 31" tires are actually 31"es tall) can be fit under a stock 4wd MJ, but only on stock rims or the tires will rub horribly on the flares. Below is my 4wd 90 on 31s with stock rims. There was a bit of rubbing on the stock lower control arms, but I swapped in WJ lowers that have the funky bend in them so all is good now.
Jeep on!
--Pete
My email:
Pete M is offline
post #5 of 5 Old 03-28-2008, 09:17 PM
MrSimon
1987 MJ Comanche
I just put 31" BFG Mud Terrains on a 4x4 with stock suspension. They fit in the wells, but rub while turning and on any type of bump. My 3" lift should be here any day now
These are just sitting in front, but you get the idea.
Here is the front one installed ... you can see its pretty stuffed.
'87 MJ, 4.0, Auto, 3" Lift, 31" BFG M/Ts, D30/35, 3.55s
MrSimon is offline
Stock Ride Height- Tire Size? Vrrooom XJ Cherokee Technical Forum 11 08-08-2012 10:15 PM
Stock Suspension Height FransWhiteXJ XJ Cherokee Technical Forum 5 12-29-2008 01:35 AM
Stock Suspension Height? mrobertson XJ Cherokee Technical Forum 4 04-13-2007 11:33 AM
What size tire with stock height? themow XJ Cherokee Technical Forum 7 09-26-2006 08:15 PM
Stock suspension height and other questions. VIVI XJ Cherokee Technical Forum 4 07-27-2004 12:53 PM
