Loss of power after overheat - JeepForum.com
post #1 of 5 Old 09-04-2013, 02:13 PM Thread Starter
ATjeep42
1988 MJ Comanche
I overheated to the point of engine stall after a bad coolant leak. After replacing lost fluid and field patching the leak engine ran OK and I've put a few thousand miles on it since. But I've noticed a significant loss of power (and it sounds like I have a mild misfire at full throttle as well), and 20% lower gas mileage. Noticed engine is running a little rich (blackish tailpipe as opposed to dark brown before), but plugs are clean. No indication of blow-by (oil clean, no visible smoke from tailpipe). No trouble codes. No fluid losses (beyond what deteriorating gaskets have been causing over the last ten years).
FYI 373,000 on original engine w/ no replacements other than typical maintenance (e.g. TPS, O2, crankshaft position sensors, plugs/wires/cap/rotor in the last two years).
Any idea what the problem might be?
1988 Jeep Comanche
4L, 4x4 5 speed manual
ATjeep42 is offline
post #2 of 5 Old 09-05-2013, 02:46 PM
TrucksBootsNGun
1988 MJ Comanche
Not to stray from the topic but you can scan your '88 MJ? I have the same truck ('88, 4L, manual etc) and I've had the dash apart a couple times messing with the dash lights and new radio and not once have I seen anything that I could use to scan the truck.
TrucksBootsNGun is offline
post #3 of 5 Old 09-08-2013, 06:37 PM
wgirvine
1992 XJ Cherokee
Start with the usual tuneup/sensors/fuel pressure items. Other than those... Hmmm.... I'm just thinking out loud here...
That's a lot of miles. Partially clogged fuel filter will show up as loss of power at heavy loads (high revs, or full throttle.) Or...
Camshaft is wearing out? (not as much lift at the valves.) Or...
The overheat softened the valve springs so now they float at high revs? (misfire)
Start with the easy stuff first...
The road goes on forever, the party never ends....
wgirvine is offline
post #4 of 5 Old 07-09-2015, 03:40 PM Thread Starter
ATjeep42
1988 MJ Comanche
Update
It's been two years. Just an update in case anyone else sees this problem - per a suggestion, I added Seafoam injection cleaner to a nearly empty fuel tank and after doing this a couple of times the power was much improved - no longer needed to drop down a gear to get over the Santa Cruz Mtns , though gas mileage is still down about 2 mpg and occasional misfire still persists. Up to 398,000k on the engine now.Firest
ATjeep42 is offline
post #5 of 5 Old 07-12-2015, 08:28 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Had a cherokee that did the same thing. After a bad overheat it ran, but seemed like it was sluggish. Changed all the fluids and cap rotor but it still ran rich. This was a 93 xj.
He coil on ours was bolted to the block and with the overheating, had gone bad enough to run, but was giving me issues. Changed the coil and it had better spark and ran a lot better. We had a similar miss in the engine occasionally too and that went away.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now
