Looking for a point in the right direction - JeepForum.com
post #1 of 9 Old 04-26-2006, 10:49 AM Thread Starter
Trickytim444
Age old question im sure has been asked before but i cant find what looking for with the search.
Is it possible to find my 88 4.0, 5spd, 4x4, shortbed comanche a 6" suspension lift for under 800 dollars in parts? Excluding wheels, tires, alignment....
i was looking at this one.... http://cgi.ebay.com/ebaymotors/Jeep-...spagenameZWD1V
let me know...thanks in advance
Trickytim444 is offline
post #2 of 9 Old 04-27-2006, 12:08 PM Thread Starter
Trickytim444
no one has any suggestions or ideas?
post #3 of 9 Old 04-27-2006, 08:51 PM
workaholic
First off, i'll say only take what I say worth a grain of salt as I am by no stretch of the imagination a 4x4 expert. now with that said, I looked at this kit and to me it just seemed to have band aid fixes to some crucial parts.
Ex:
3" spring and a 3" spacer up front (why not a full 6" spring?)
extended brake lines (why not new stainless lines that are 6-8" longer than stock?)
no new front lower control arms (I have heard that is a big no no with that size of a lift)
Personally i'm a big fan of the rear SOA bolt on kit they offer.
I imagine that the kit works great IMHO alot of it would have to do with weather you are comfortable driving a truck that is lifted in that manner or not.
Tom
workaholic is offline
post #4 of 9 Old 04-27-2006, 09:45 PM
DirtyCommanche
That kit is garbage, IMHO. I've posted regarding it before.
Personally, I think you could put together a better 'kit' for under $800.
Do you have any fab skills? The rear SOA is easy, just weld some spring perches on top of the axle. The front is more ugly in that you'll probably want at least longer LCAs and probably UCAs if you want to have any caster at all. And you'll need a track bar/bracket. Then springs and shocks. And brake lines front and rear.
Just forget about that swaybar nonsense too. And that ******* brake prop valve.
It's that or buy this kit and do what they want and add a ****load of shims behind the LCAs to get the caster close. Not smart.
DirtyCommanche is offline
post #5 of 9 Old 04-27-2006, 10:10 PM
cj7xjmj
cj7xjmj's Avatar
In order to do 6" correctly there are 2 routes. Long arms or drop brackets. I have run both types of suspension, and both had pluses and minuses.
For around the 800 dollar mark,
RE Drop Brackets. You will need to fab your own drop bracket supports as the ones RE sells wont work with the MJ upfront.
RE HD trac bar and mount
Rusty's 6.5 springs
DT3000 shocks 28", with JKS bayonet eliminators
Crown front brake lines 30"
For the rear you will need some SOA perches, and a 30" brake line
You can use your stock upper and lower control arms with the Drop brackets and have zero issues. I do recommend welding some plate on the bottom sides this will stiffen them and prevent nasty things from happening.
I ran that very setup till I went to Terra long arms. Some ppl say that Terra Flex upgrade LA kit isn't worth a poo, but I have yet to see what they are running Yes it uses a parrallel 4 link, instead of the radias arm setup. both setups have pluses and minuses.
BTW I used all the same parts on my rig still except I am running LA's now
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #6 of 9 Old 04-28-2006, 05:33 PM
workaholic
Rusty's 6.5 springs
great info!! who is RE?
Tom
post #7 of 9 Old 04-28-2006, 05:34 PM
MISFIT
SCREW THE COILS AND GET SOME LEAVES!!! :rolling:
if cheap is what you're looking for, find some junkyard leaves and throw them on. you'll need to fab a front spring hanger and if you're any good at fabbing, you can use your stock LCA bracket to mount the leaves in (now, the shackle would be on the front of the frame. IMO, it's great off-road, but sorta sucks on-road). the rear is easy, just weld new perches on it (correcting the pinion-angle while you're at it). a SOA on the rear will give you ~5-6" of lift. if you want more, just throw in some AAL's.
$.02
'90 Manche---Full Widths, 37s, Blah Blah Blah
MISFIT is offline
post #8 of 9 Old 04-28-2006, 05:35 PM
MISFIT
Tom
RUBICON EXPRESS!!!
MISFIT is offline
post #9 of 9 Old 05-03-2006, 05:17 PM
workaholic
Rusty's 6.5 springs
are there drop brackets you wouldn't need to fab anything for? and if so what brackets would you need?
Tom
need 02 sims where to buy..point me in direction lowazztruck XJ Cherokee Technical Forum 7 01-23-2009 10:23 PM
RE 4.5 leafs or rustys 4.5 springs, point me in the right direction jersey_jim XJ Cherokee Technical Forum 10 12-22-2008 11:55 AM
Point me in the right direction wannabexj XJ Cherokee Technical Forum 19 01-20-2008 02:49 PM
point me in the right direction TJSahara XJ Cherokee Technical Forum 5 01-06-2005 07:38 PM
Could anyone point me in the right direction? cherokman XJ Cherokee Technical Forum 1 04-28-2002 09:48 PM
