Looking at new Vintage tires . . . - JeepForum.com
post #1 of 10 Old 01-10-2010, 05:34 PM Thread Starter
AMCSportTruck
1988 MJ Comanche
Not sure which size tires i should go with, G78-15's 28.5" tall or 7.00-15's 30" tall.
G78-15:
http://www.universaltire.com/truck-a...r-traxion.html
7.00-15:
I'm going to go with one of the 2 tires for sure as i love the tread design but i am unsure of which size would fit best, but i plan to mount them up on some nice polished wheel's should look very killer, i don't drive far so even tho there biasply they should wear decent and last a number of years.
Mike
AMCSportTruck is offline
post #2 of 10 Old 01-13-2010, 03:26 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No lift then?
Maybe the 28.5's might be the best bet.
I like these!
Military Jeep Tires - L & L Repair/tirewiz.com
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 10 Old 01-13-2010, 03:38 PM Thread Starter
AMCSportTruck
1988 MJ Comanche
Lift on a 2WD ? why . . .
Mike
post #4 of 10 Old 01-13-2010, 03:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Mainly for aesthetics & tire clearance to get the "look" you might want.
Many newer trucks (2WD) have "leveling kits" to lift the front & make the truck sit slightly higher.
Altering ride height (up & down) on all kinds of vehicles is nothing new.
Max
Mean Max is offline
post #5 of 10 Old 01-13-2010, 03:54 PM Thread Starter
AMCSportTruck
1988 MJ Comanche
what would on need to do to fit the 7.00-15's aka 30's ? . . . Is there an easy way to cheat the extra 1" of the suspension ?
they'll more then likely clear now but and extra .75"-1.25" of clearance wouldn't hurt none
Mike
post #6 of 10 Old 01-13-2010, 04:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Look for kits/parts like these. Spring spacers for the front coils & shackles for the rear leaf springs.
Daystar KJ09105BK - Daystar Econo-Lift Kit with 1¾" Coil Spring Spacer and 1" Rear Shackles in Black for 84-01 Jeep® Cherokee XJ - Quadratec
Max
Mean Max is offline
post #7 of 10 Old 01-13-2010, 04:12 PM Thread Starter
AMCSportTruck
1988 MJ Comanche
Very cool. . .book mark and will gotten with the new tires.
Mike
post #8 of 10 Old 01-13-2010, 04:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Make sure you post back with pics!
Max
Mean Max is offline
post #9 of 10 Old 01-13-2010, 04:28 PM Thread Starter
AMCSportTruck
1988 MJ Comanche
But of course, why wouldn't I ? . . . those tough treads polished wheel's taller stance . . . who wouldn't ?
Mike
post #10 of 10 Old 09-25-2013, 02:12 PM
jrives
2010 JK Wrangler
Super Traxion 750-16
Which did you finally chose? Would like to see.
jrives is offline
BF Goodrich A/T tires vs. Uniroyal Winter tires for 14% grade? Josh8810 XJ Cherokee Technical Forum 3 12-30-2009 05:34 PM
Removing Tires From Rims-Anyone Want Some Free 35" Tires? :) mgramann XJ Cherokee Technical Forum 15 12-15-2009 01:58 PM
tires tires tires.. narrowed list to 3. what do you have? AustinTexasXJ XJ Cherokee Technical Forum 17 07-28-2009 08:58 PM
any deals on LT tires?, & biggest tires for 2" lift? subtle_driver XJ Cherokee Technical Forum 8 10-16-2008 08:00 AM
will I need a new speedo gear from stock tires to 30/9.5/15 tires? Lution XJ Cherokee Technical Forum 19 01-17-2007 05:22 PM
