Looking at an 88 Comanche...what to look for? - JeepForum.com
post #1 of 3 Old 01-02-2013, 02:37 PM Thread Starter
Mosinguy
I'm going to see a 4 cyl 5 speed Comanche soon. What should I look for? Guy says no rust. Should I flush all the fluids? What weight/brand of fluid should I use in the: transmission, differential, transfer case, radiator, and engine? How do you drain fluid from everything? The engine should be easy enough to do but what about everything else? Thanks!
EDIT: How do I do a tune-up? How do I grease joints and what joints should be greased? Is there a certain type of brake pads it takes? What air filter should I use? Part numbers are helpful!
Mosinguy is offline
post #2 of 3 Old 01-02-2013, 07:12 PM
butchershop
1988 MJ Comanche
Most info for Comanches can be found here: www.comancheclub.com
Helpful guys over there too.
butchershop is offline
post #3 of 3 Old 01-03-2013, 08:43 PM
97_4popper
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
