looking at an 88 - JeepForum.com
post #1 of 13 Old 01-05-2014, 04:04 AM Thread Starter
SOWEGA TJ
looking at an 88
I'm looking at an 88 MJ SWB 2WD.
Any tips or suggestions on what to look out for? What do I need to inspect?
Thanks
SOWEGA TJ is offline
post #2 of 13 Old 01-05-2014, 05:02 AM
87MJTim
1987 MJ Comanche
Rust, rust and more rust. Look at the floor boards. Pull up the carpet and check there; look in the wheel wells.
What eng and trans does it have? If it has a 4.0 5sp, ask about the trans. Is it the original BA10/5? Not a bad trans, but the internal slave is an issue.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #3 of 13 Old 01-05-2014, 12:54 PM Thread Starter
SOWEGA TJ
Minimal rust. 4.0 5sp. New slave cylinder, clutch, master cylinder. 160k miles
post #4 of 13 Old 01-05-2014, 01:50 PM
Nick05
1994 XJ Cherokee
i have heard the clutches are bad about leakin onto the floor and rustin them out, so check there for sure
Nick05 is offline
post #5 of 13 Old 01-05-2014, 03:13 PM Thread Starter
SOWEGA TJ
Bought it. Will pull carpet and seat this week
post #6 of 13 Old 01-05-2014, 03:47 PM
87MJTim
1987 MJ Comanche
Run your fingers over the top and reach behind the fuse box. This is where the master cylinder leaks.
Congrats on the purchase.
Check out www.comancheclub.com. Lots of good info specifically for MJs.
Tim
87MJTim is offline
post #7 of 13 Old 01-05-2014, 06:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Click on the link in my signature and start with Post #1. Congratulations!!!!!
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #8 of 13 Old 01-06-2014, 09:22 AM Thread Starter
SOWEGA TJ
Anyone know if stock TJ suspension will work on the front? Or if a TJ exhaust will bolt on?
post #9 of 13 Old 01-06-2014, 07:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Maybe springs, but not exhaust.
post #10 of 13 Old 01-06-2014, 08:43 PM Thread Starter
SOWEGA TJ
what about stock lower control arms? would the springs lift it any or perhaps level it to rear height?
Thanks.
post #11 of 13 Old 01-17-2014, 02:31 AM Thread Starter
SOWEGA TJ
pulled seat and carpet....soaked carpet and padding but thankfully minimal rust...may replace some of floor pan instead of welding up few holes. then I will prime and bedline the interior to stop future rust...
post #12 of 13 Old 01-17-2014, 03:15 AM
Solidkm
you didnt buy ****.... if you didnt post a picture.
theres a soft spot in my heart for MJs
Solidkm is offline
post #13 of 13 Old 01-17-2014, 03:42 AM Thread Starter
SOWEGA TJ
how's this? lol
