Little help pleas - JeepForum.com
post #1 of 6 Old 04-20-2013, 08:10 PM Thread Starter
Michaelgoesrawr
Michaelgoesrawr's Avatar
Little help pleas
I go to blow out the air filter and I notice a broken air hose. Have no clue where it goes it what it does.
Also there is this broken hose on the ccv system. Related?
Thanks for any help. This is a far cry from my YJ
Michaelgoesrawr is offline
post #2 of 6 Old 04-24-2013, 07:12 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This help?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 6 Old 04-24-2013, 09:15 AM Thread Starter
Michaelgoesrawr
Originally Posted by cruiser54
This help?
Yeah man! I'm sure that'll work. Thank you.
post #4 of 6 Old 04-25-2013, 05:27 AM
zackcj7
You can buy that whole vacuum assembly new from Napa. If yours is like mine and the hoses are old and brittle you might consider just replacing them.
zackcj7 is offline
post #5 of 6 Old 04-25-2013, 06:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Renix Vacuum Harnesses
The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK-715-1366.
The tube from the rear of the valve cover to the intake manifold is part number 715-1365.
Revised 09-11-2012
post #6 of 6 Old 04-25-2013, 11:22 AM Thread Starter
Michaelgoesrawr
I actually got the left half of the assembly last year some time. The other part was fine but that needs to get done too now. Thanks for the help guys.
