Lift & Tire Help/opinions - JeepForum.com
post #1 of 5 Old 02-28-2008, 06:20 PM Thread Starter
Comanche Devil
1989 XJ Cherokee
OK just starting the my cheap lift on the Comanche Devil. Put in the T-Bird springs upfront. Netted 4" lift, today I made sway bar disco's from 2000 Grand links , this weekend I will be lifting the rear, so here is the Question. Do I re-arch the spring pack to achieve the 4" needed or make up longer shackles, or do the both? And about how much arch to net 4"? I know for a 3" lift the springs need a 5" arcs for a 4" would you go 7" or 8"arc? Don't want to do a soa because i will get 4.5-5" and thats too much. Now for tires do I go with 31" or 32"? I want some opinion I know there are only a 1" but what is the pros/cons. Need some experience opinions.
1989 Cherokee "notchback" 4 inch lift, 4.0L Renix, AW4, 231, fozzy locked Dana Turdy Five, HpD30, 3.55's for now, Rollin on 32"MTR's, Homemade front & rear bumpers with removable winch
Comanche Devil is offline
post #2 of 5 Old 02-29-2008, 10:05 AM
CanadianJeep86
I'd go with the 7" arc and 32's. 31's would look pretty small with a 4" lift. Did you get a dropped pitman or anything similar to correct your steering?
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline
post #3 of 5 Old 03-01-2008, 06:02 AM
Dr.Thunder
1988 MJ Comanche
you could do what i did and do the soa with a cherokee shackle, cherokee shackles are about an inch shorter than mj shackles and will lower you about a half inch. however it is still pretty high in the back
Dr.Thunder is offline
post #4 of 5 Old 03-20-2008, 06:14 AM
NWDave
What year T-Bird springs are best? I found some at Auto Zone for $71 a pair.
2007 JK-X 2dr soft top, OME MD/Bilstein 5100's= 3.5" lift, 15x8" Cragar Soft 8's, 35x12.50-15 BFG KM2's.
NWDave is offline
post #5 of 5 Old 03-20-2008, 11:45 PM
carnuck
1984 J-Series Truck
SOA and take a leaf or two out!
carnuck is offline
Another tire thread..opinions. keaton XJ/MJ Cherokee Non-Technical Forum 9 06-18-2013 08:53 PM
Opinions on tire width. cheesehead XJ Cherokee Technical Forum 6 04-10-2009 08:30 PM
lift/tire opinions riggs51 XJ Cherokee Technical Forum 14 11-27-2007 03:57 PM
Tire Choices...Opinions? FernGreenXJ XJ Cherokee Technical Forum 10 10-14-2006 04:28 PM
Opinions on my next lift/tire setup wanted... atfrith XJ Cherokee Technical Forum 22 05-05-2005 06:25 PM
