Knock Sensor? - JeepForum.com
post #1 of 21 Old 10-04-2012, 06:59 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Knock Sensor?
Hey, I found out the knock sensor broke off my 89 comanche motor when we were puttin it in. I looked one up and there 60 plus dollars . Do you think its worth getting one from a junkyard, do they have a tendency of going bad? Or schould I just buy a new one. Let me know what you think, thanks in advance.
JeepComanche89 is offline
post #2 of 21 Old 10-05-2012, 08:01 AM
DeejayZeejay
1994 ZJ
I was told knock sensors are worthless.... They tend to not be accurate. Not sure if they go bad. But if you get it cheap at the junkyard, its worth a try.
Jeeps 4 Life!
DeejayZeejay is offline
post #3 of 21 Old 10-05-2012, 01:00 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Hmm, does that mean it will run without one?
post #4 of 21 Old 10-05-2012, 10:04 PM
DeejayZeejay
1994 ZJ
Dunno. Maybe...
Jeeps 4 Life!
post #5 of 21 Old 10-05-2012, 10:52 PM
mj40
1989 MJ Comanche
knock sensors for adjusting timing for the computer, it'll run without, but any knock/pinging in the engine and the computer will not see it or adjust the timing for it..and you may get a check engine light when the computer see's its gone.
mj40 is offline
post #6 of 21 Old 10-06-2012, 10:10 PM
ftpiercecracker
1990 MJ Comanche
You need a Knock sensor, period. Yes it will run without it, but i would not advise it. You can try a junk yard, just make sure to replace it with a good one when you do get the money.
ftpiercecracker is offline
post #7 of 21 Old 10-07-2012, 05:15 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Okay, thanks for the help. Guesse ill just have to buy a new one to be safe, dont want to risk anything if it does matter
post #8 of 21 Old 10-07-2012, 09:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No check engine lights on a REnix.....
cruiser54 is offline
post #9 of 21 Old 10-07-2012, 09:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
A good used one would probably be fine. They rarely fail.
post #10 of 21 Old 10-08-2012, 12:23 PM
97_4popper
Hell, I didn't know they had 'em.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #11 of 21 Old 10-08-2012, 05:26 PM Thread Starter
JeepComanche89
1989 MJ Comanche
If i can find one ill probably just do that, but if not ill buy new
post #12 of 21 Old 10-08-2012, 05:27 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Me neither, had to post on here to find out what it was haha
post #13 of 21 Old 10-08-2012, 08:48 PM
ftpiercecracker
1990 MJ Comanche
FWIW renix motors also have 3 separate temperature sensors. 1. back driver side of the head 2. driver side of the rad 3. driver side of engine block, under the intake man.
post #14 of 21 Old 10-08-2012, 09:12 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Coolant temp SENDER at the rear driver's side of the head, for the instrument panel gauge or light. Coolant Temp SENSOR to give info to the ECU is located on the driver's side of the block.
Coolant Fan SWITCH is located in the radiator on the driver's side lower to engage the electric fan.
post #15 of 21 Old 10-09-2012, 04:44 AM Thread Starter
JeepComanche89
1989 MJ Comanche
I know i have the one under the manifold, im not sure about the one in the head, and i replaced the rad and im pretty sure it doesn't have any place for a sensor. And i defiantly do not have an electric fan.
