JY o2 sensor? - JeepForum.com
post #1 of 7 Old 04-13-2013, 12:59 AM Thread Starter
snakedoc67
1987 MJ Comanche
JY o2 sensor?
Looking at picking up an O2 sensor from a JY cherokee for my Comanche since I cant afford a new one at this time. Have looked thru the posts the last few days here and on ComancheClub but have not seen any way of testing to see if its any good. Any ideas for a test for the O2 sensor and what has been the experiences with a sensor from the jy? http://www.jeepforum.com/forum/images/smilies/dunno.gif
snakedoc67 is offline
post #2 of 7 Old 04-13-2013, 02:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
needs to be running and you need an analog meter to watch the voltage switching.
but you can pretty much assume that any junk yard o2 is going to be too dirty to work well. and you can't clean an o2 sensor effectively.
ratmonkey is offline
post #3 of 7 Old 04-13-2013, 02:36 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
ULTRAPOWER Part # 2343005
$23.79 at www.rockauto.com
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 7 Old 04-13-2013, 07:27 AM
5-90
5-90's Avatar
1988 XJ Cherokee
With the engine off and sensor unpowered, you can test the heating element - but that does nothing to measure the actual effectiveness of the sensor proper.
You'd need to run the engine and use backprobe pins on an analogue meter or an oscilloscope to read the sensor switching - and that won't happen at a breaker's.
A HEGO is something I would flatly refuse to buy from a breaker's. Yes, you may get a useful one, but you won't know how much life it has left in it - and it's at least as likely you'll get one that won't work worth a crap.
My advice? Start saving your nickels, and plan to buy a new replacement. They're less than $100 for a "direct fit" replacement, you may as well do it right the first time (save yourself the work, save the money for having to buy it twice - and a failed HEGO from the breaker's will be effectively the same as what you're dealing with now - the ECU will "swing rich" if the signal from the HEGO is bunk, to prevent engine damage (13.2-13.5:1, usually. Rich enough to prevent detonation, but not so rich as to cause washdown.)
Leave it be, save your money to do it right the first time. It's an MJ, so it will be RENIX or OBD-I (depending on year,) and neither is horribly picky about the HEGO RENIX can ignore it readily, and OBD-I will eventually throw a code - which can be cleared when you replace the sensor with a new part.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 7 Old 04-14-2013, 12:36 AM Thread Starter
snakedoc67
1987 MJ Comanche
thanks for the tips, looks like i'll have to put up with 6mpg for awhile until i can get some work.
post #6 of 7 Old 04-14-2013, 07:37 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Lots more wrong than an 02 sensor to give you 6 MPG.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #7 of 7 Old 04-14-2013, 10:40 AM
5-90
5-90's Avatar
1988 XJ Cherokee
You're probably due for MAP and IAT, in addition to HEGO.
The HEGO is an uncommon part for RENIX - but the MAP and IAT are both standard GM items, available anywhere for a reasonable cost. The MAP and IAT are used to generate initial data for fuel trim ("speed/density" system,) and the HEGO is used to provide a feedback loop. All three are important.
(The CTS also plays a part in fuel metering, but it's not as critical as the MAP and IAT. Fortunately, it is also a standard GM part.)
5-90 is offline
