-   MJ Comanche Technical Forum (http://www.jeepforum.com/forum/f53/)
-   -   JY o2 sensor? (http://www.jeepforum.com/forum/f53/jy-o2-sensor-1508489/)
snakedoc67 04-12-2013 11:59 PM
JY o2 sensor?
Looking at picking up an O2 sensor from a JY cherokee for my Comanche since I cant afford a new one at this time. Have looked thru the posts the last few days here and on ComancheClub but have not seen any way of testing to see if its any good. Any ideas for a test for the O2 sensor and what has been the experiences with a sensor from the jy? http://www.jeepforum.com/forum/images/smilies/dunno.gif
ratmonkey 04-13-2013 01:11 AM
needs to be running and you need an analog meter to watch the voltage switching.
but you can pretty much assume that any junk yard o2 is going to be too dirty to work well. and you can't clean an o2 sensor effectively.
Mean Max 04-13-2013 01:36 AM
ULTRAPOWER Part # 2343005
$23.79 at www.rockauto.com
Max
5-90 04-13-2013 06:27 AM
With the engine off and sensor unpowered, you can test the heating element - but that does nothing to measure the actual effectiveness of the sensor proper.
You'd need to run the engine and use backprobe pins on an analogue meter or an oscilloscope to read the sensor switching - and that won't happen at a breaker's.
A HEGO is something I would flatly refuse to buy from a breaker's. Yes, you may get a useful one, but you won't know how much life it has left in it - and it's at least as likely you'll get one that won't work worth a crap.
My advice? Start saving your nickels, and plan to buy a new replacement. They're less than $100 for a "direct fit" replacement, you may as well do it right the first time (save yourself the work, save the money for having to buy it twice - and a failed HEGO from the breaker's will be effectively the same as what you're dealing with now - the ECU will "swing rich" if the signal from the HEGO is bunk, to prevent engine damage (13.2-13.5:1, usually. Rich enough to prevent detonation, but not so rich as to cause washdown.)
Leave it be, save your money to do it right the first time. It's an MJ, so it will be RENIX or OBD-I (depending on year,) and neither is horribly picky about the HEGO RENIX can ignore it readily, and OBD-I will eventually throw a code - which can be cleared when you replace the sensor with a new part.
snakedoc67 04-13-2013 11:36 PM
thanks for the tips, looks like i'll have to put up with 6mpg for awhile until i can get some work.
cruiser54 04-14-2013 06:37 AM
Lots more wrong than an 02 sensor to give you 6 MPG.
5-90 04-14-2013 09:40 AM
You're probably due for MAP and IAT, in addition to HEGO.
The HEGO is an uncommon part for RENIX - but the MAP and IAT are both standard GM items, available anywhere for a reasonable cost. The MAP and IAT are used to generate initial data for fuel trim ("speed/density" system,) and the HEGO is used to provide a feedback loop. All three are important.
(The CTS also plays a part in fuel metering, but it's not as critical as the MAP and IAT. Fortunately, it is also a standard GM part.)
The time now is 06:53 AM.
