just double checking the info - JeepForum.com
post #1 of 8 Old 06-17-2008, 04:52 PM Thread Starter
juiceyx87
1986 MJ Comanche
so i settled for a 3" kit for now to keep the 33's from rubbing alot... i read in a previous post that i will possibly be needing lower control arms and longer brake lines in the front... what about the sway bar should i get some of them quick disconnects or should the stock deals work alright till i can get some money for them?
also should i get a new drop pitman arm? i do hear a knocking sound when i turn tho when i grease it up i dont... is that a sigh of my pitman arm going bad? im sure an XJ's will fit. yes? thanks for the help guys (and girls)
Juicey
86 MJ X: 2.8L V6- lifted 3" on 33x10.5x15 BFG mud terrain
04 chevy aveo: 1.6L I4-redneck cold air intake and ridiculous muffler
juiceyx87 is offline
post #2 of 8 Old 06-18-2008, 11:57 AM
Pete M
1988 MJ Comanche
Which kit are you contemplating (that doesn't come with lower control arms or a swaybar fix)?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 8 Old 06-18-2008, 03:29 PM Thread Starter
juiceyx87
1986 MJ Comanche
i purchased the
and got it well most of it today, for some 1 of the 3 boxes made it almost all the way here and disapeared ups caught it and is contacting rustys
Juicey
post #4 of 8 Old 06-19-2008, 01:29 AM
Pete M
1988 MJ Comanche
With 33s, you're definitely going to want lower control arms to center the tire in the wheelwell. For the swaybar fix, I prefer the longer links because then you can get the disconnect ones and pop them for offroading. With 33s, you might also need to look into lengthening the bumpstops to keep the tire out of the fenders.
Jeep on!
--Pete
My email:
Pete M is offline
post #5 of 8 Old 06-19-2008, 11:53 AM
maddzz
1989 MJ Comanche
Originally Posted by juiceyx87 View Post
i purchased the
What? Is this English?
maddzz is offline
post #6 of 8 Old 06-20-2008, 08:50 PM Thread Starter
juiceyx87
1986 MJ Comanche
that was english of some sort... but UPS lost one of the boxes (i only got 2 of 3) and i figured i would wind up needing or atleast wanting the quick discos and maybe LCA's i know the quick discos will be a easy replacement but what bout the LCA's would they be some what easy? ide like to do all the work my self so i can become one with my comanche (zen like)...the shocks i know are cake springs look semi easy the A-A-L's seem a lil harder then they look but im sure i could manage... any words of wisdom from u more experienced folks?
Juicey
post #7 of 8 Old 06-21-2008, 06:42 AM
Do It xj
control arms can be tricky because when you un hook the old ones the axle likes to roll back on you, but its easily doable and a ratchet strap comes in handy.
-94' cherokee sport- 2 door,5.5 inch lift,thule light bar,daylighters,bushwacked,33x12.50 BFG KM2's-sold
-99' cherokee sport-4 door-
-03' wrangler sahara- 4.5" susp, 1.25 bl/mml, w/35 BFG MT's, Flowmaster super44
Do It xj is offline
post #8 of 8 Old 06-21-2008, 02:54 PM
Pete M
1988 MJ Comanche
Do one arm at a time and be prepared to wrestle with the axle a bit. It's not all that hard, just tricky sometimes. Installing coil springs is harder in my opinion.
--Pete
My email:
Pete M is offline
I am new here just checking in spooledberries XJ/MJ Cherokee Non-Technical Forum 5 01-25-2010 10:08 AM
Tshifter handle removal double checking 98cherokee19 XJ Cherokee Technical Forum 2 07-09-2009 06:46 PM
Just Double Checking Eje004 XJ Cherokee Technical Forum 5 01-11-2008 08:40 AM
checking IAC? NCwheeler XJ Cherokee Technical Forum 1 11-29-2006 03:22 PM
Double Checking before I order KidWithACrayon XJ Cherokee Technical Forum 28 07-06-2006 10:37 AM
