Just cant stop - Page 2 - JeepForum.com
post #16 of 20 Old 09-10-2013, 05:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you try bleeding the master, you MAY see that very little fluid is coming out around the fittings. But, it's harder to tell than when you're using a regular bleeder.
What did the original fluid look like?
Real nasty?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #17 of 20 Old 09-10-2013, 06:14 AM Thread Starter
SamanthaRae
The original fluid wasn't that bad. Haven't tried to bleed the mc yet. Does anyone know if it has anti lock brakes?
SamanthaRae is offline
post #18 of 20 Old 09-10-2013, 06:21 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Only you. We need a pic of the Master to tell from here.
post #19 of 20 Old 09-13-2013, 04:58 PM
carnuck
1984 J-Series Truck
It has a level sensor on the rear axle that restricts flow when there isn't a load. I popped mine off (the rod that is) and lifted it up to bleed. When that wasn't enough (I had a broken line in the back that I replaced) I loosened the return line under the pressure differential valve (under the brake booster/master) and got LOTS of air from there. When I went to 33" tires (33/9.50/15) i removed the return line (plugged it with a cap on the PD valve by the master cylinder and bypassed the load level valve in the rear) The drawback to this is the level sensor is an anti-skid device so you have to be careful in the rain. With better front brakes (off a ZJ) and an upgraded master/booster ('96 XJ) I can stop at 55 mph while pulling a 3500 lb load while having a motor/trans in the back of the truck for "ballast".
Comanches didn't get factory ABS. Just the rear anti-skid valve.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #20 of 20 Old 09-14-2013, 12:41 PM Thread Starter
SamanthaRae
Just put a new master cylinder on it and still nothing. Almost like its worse then before. Bled everything. Still air in the lines. Checked all my connections and lines. No leaks.
