Jeep Comanche 2.5L RWD to 4WD conversion. - JeepForum.com
post #1 of 3 Old 04-01-2012, 03:03 PM Thread Starter
mtruesdell0208
1988 MJ Comanche
Hi, I'm looking forward to this project, I own an 88 Jeep Comanche Pioneer with a 2.5L in it. The truck has 160,000 miles on it, and the engine runs near perfect, so I would like to avoid doing an unnecessary engine swap. I would like to convert this to 4WD as it is RWD as it is. I have an aisin AX4 manual transmission. I have done some research and found that to do so, and not switch transmissions, I can switch the output spline on the transmission to accept a N231 Transfer case, and change my front axle with one with a differential. The N231 transfer case is not a problem as I believe they are commonly found in XJ Cherokees 87 and up, and wranglers. The f ront DIFF is a little more difficult, Will a front diff and axle off of a Cherokee work? Even if it is a 4.0, I have 4:10 gears in my rear which means I need 4:10 gears in the front. Do the 4.0 cherokees come with the 4:10 gears or do I need to keep looking?
mtruesdell0208 is offline
post #2 of 3 Old 04-01-2012, 05:56 PM
LimeLJ
LimeLJ's Avatar
Some rare Cherokees did come with 4.10 gears. A Cherokee D30 front axle will work. Most likely you will just have to get whatever you can and have it regeared.
To swap the transmission output it would be easiest to pull the transmission. If you are pulling the transmission you might as well put a NP231 already mated to a properly setup transmission. Save the trouble of breaking it down to swap the output shaft.
LimeLJ is offline
post #3 of 3 Old 04-04-2012, 04:41 PM
lsmurphy
Look for a 94+ XJ with with an AX5 and it will come with the 4.10 front axle.
No you cannot just swap the tail shaft........You need a 4x4 trans.
I have done this swap.
94+ will have an external slave........this is what you want.
You also need linkage and DS.
lsmurphy is offline
2wd comanche conversion to 4wd Danettelouise MJ Comanche Technical Forum 5 04-09-2012 11:39 PM
4x4 Conversion, Jeep Comanche, BA-10 to AW4 ?'s 88Comanche818 XJ Cherokee Technical Forum 1 06-22-2010 05:31 PM
comanche 2wd 4x4 conversion workinman MJ Comanche Technical Forum 7 08-06-2009 08:12 PM
87 comanche conversion franks67gto MJ Comanche Technical Forum 11 11-28-2006 10:37 AM
Comanche 4wd conversion in JP MJDriver MJ Comanche Technical Forum 0 01-30-2006 12:50 PM
