jeep cherokee pcm - JeepForum.com
post #1 of 6 Old 10-04-2012, 03:00 PM Thread Starter
chrisreusch
jeep cherokee pcm
i have a jeep cherokee that needs to have the pcm replaced. do i have to get it flashed to my vin or can i just switch it out with another one. it is a 2000. please help
chrisreusch is offline
post #2 of 6 Old 10-06-2012, 10:18 PM
ftpiercecracker
1990 MJ Comanche
flashed to your vin?? not sure what you mean, but it shouldnt really matter if it is what i think it is. It comes preprogrammed with "default" settings and will "learn" ,if you will, how your engine operates best. The best thing to do is to replace it and then drive a couple gentle laps around the block.
question, how do you know your PCM is what is bad?
ftpiercecracker is offline
post #3 of 6 Old 10-07-2012, 12:57 AM
USMC_XJ
2003 WJ
Unless you have the SKIM security, you don't need to have it reflashed. Make sure the new one you get is the same.part number, or at least an updated one. Usually it works by adding 2 letters to the end of the part number. IE, 123456789AD has revisions made and is still able to replace 123456789AB.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #4 of 6 Old 10-08-2012, 02:44 PM Thread Starter
chrisreusch
when the auto mechanic ran a test the everything was working and he overrode the system and started it. after i shut it off it would not start. the fuel pump was working so the mech said it was the pcm
post #5 of 6 Old 10-08-2012, 11:12 PM
Reptile
1991 XJ Cherokee
What do you mean he 'overrode' the system? If your key is gray, you have SKIS/SKIM. You need a DRBIII scan tool (about 5 grands) to reprogram the VIN in the ECU.
Reptile is offline
post #6 of 6 Old 10-09-2012, 06:45 AM
97_4popper
Had to replace it on the 97 TJ. I bought it online and the company I bought it from flashed it with the vin. So, I would assume your 2000 needs it as well. Did you post this on teh Cherokee forum? This is the comanche forum.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
