Instrument Cluster swap & high oil pressure reading - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Instrument Cluster swap & high oil pressure reading
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-04-2012, 02:20 PM   #1
RoadHammer1
1988 MJ Comanche
Hi Everyone,
I recently swapped a full instrument cluster into my 88' Comanche. It's nice to have gauges rather than warning lights, but I question the oil pressure reading. According to the gauge the engine has 60 psi of oil pressure at cold idle and running. When up to temperature, about 210, the gauge will drop to about 30 psi but that still seems high. I like to think that this engine is capable of that kind of oil pressure but with 183K miles on a 4.0L, it doesn't seem likely to me. The cluster came out of a 90' model Cherokee and the sender is new.
I invite your comments.
Mark B...
RoadHammer1 is offline   Reply With Quote
Unread 06-04-2012, 04:05 PM   #2
cruiser54
1990 MJ Comanche
Sounds fairly normal to me.
cruiser54 is offline   Reply With Quote
Unread 06-09-2012, 10:46 PM   #3
theguywithjeeps
1989 MJ Comanche
that's called a jeep son. haha you got another 183,000 miles to go. congrats on the successful cluster swap!
theguywithjeeps is offline   Reply With Quote
Unread 06-30-2012, 10:15 PM   #4
PaulCa13
1991 MJ Comanche
My '91 Comanche with 63,000 miles has virtually the same oil pressure readings. I'd say you've got a well maintained engine. If you're worried, go get a cheapo SunPro oil pressure gauge at a local auto parts store, hook it up under the hood and see if it shows any difference.
PaulCa13 is offline   Reply With Quote
Unread 07-04-2012, 04:54 PM   #5
Reptile
1991 XJ Cherokee
The gauge is supposed to be calibrated with the sensor. If the odd pressure readings happened after the panel swap that could be your problem.
Reptile is offline   Reply With Quote
