Injector question - JeepForum.com
post #1 of 10 Old 11-22-2012, 09:04 AM Thread Starter
Rican142
Injector question
What are the tell tale signs of fouled injectors?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 10 Old 11-22-2012, 05:06 PM
ftpiercecracker
1990 MJ Comanche
An injector with bad seals will be spraying/leaking fuel terribly. But as for an injector thats no longer opening/closing i am not so sure.
ftpiercecracker is offline
post #3 of 10 Old 11-22-2012, 09:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If they're original Renix injectors with over 100,000 miles, they need to be replaced with later model ones.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 10 Old 11-22-2012, 11:49 PM Thread Starter
Rican142
Well my truck is spitting and sputtering with about 95000 miles on it and more than likely are original.
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #5 of 10 Old 11-22-2012, 11:51 PM Thread Starter
Rican142
And whats happening is that as im driving, at te top end of every gear it starts kickig like it feels like its poping out of gear then going back it, and theres alot of back firing. But it clears up when i stomp on the gas
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 10 Old 11-23-2012, 05:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Couldn't hurt to replace them if you have the funds.
post #7 of 10 Old 12-10-2012, 05:26 PM
JeepComanche89
1989 MJ Comanche
May be a little late but i just bought remanufactured injectors off ebay 125 for a set. There 4 hole bosh injectors
JeepComanche89 is offline
post #8 of 10 Old 12-11-2012, 02:42 PM
ftpiercecracker
1990 MJ Comanche
new injectors solve your problem?
post #9 of 10 Old 07-23-2013, 12:37 AM Thread Starter
Rican142
Hey just catching up on old posts, it wasn't the injectors, turned out to be a cracked rotor cap, and a bad oxygen sensor x.x
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #10 of 10 Old 07-23-2013, 06:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Seems to ba alot of that lately oin all of the forums. People chasing their tails looking for issues in the injection system when normal maintenance items have failed or not been replaced at the recommended intervals. Especially distributor caps, the ones with aluminum contacts.
Every 30,000 a 4.0 should get new plugs. I like NGK coppers. Can't go wrong. No need for Miracle Plugs. Napa Belden plug wires with their Premium cap and rotor which have the brass terminals.
