Ignition Upgrades to a 90' MJ 4.0? - JeepForum.com
post #1 of 5 Old 07-31-2013, 09:56 PM Thread Starter
hakukamana
I know that I have a Renix fuel management & ignition system, I was wondering if the upgrades like Team Rush can be done on the 4.0 Renix. It is MPI, and I have done a Nutter bypass, and a team rush upgrade on a friends 89 YJ. Worked great. But this has a TB not a BBD, and is Multi Port injected. I have done a lot of the ground upgrades & the connector reconditioning. Just wondering if anyone has any experience with a MJ motor.
93 YJ 5.2L Magnum, Custom rear bumper & swing out tire carrier, Ford Explorer electric seats, Ford 8.8, TW DS, SYE, NV231D, Autometer gauges, Rhinolined interior,Bushwacker flares, LED Lighting all around, MT Classic II, BFG 32/11.50/15, Warrior Body Armour, ZJ PV, DD BB, 52mm TB, Ford 23# Injectors, HS 1.7 RR, KC lights, RE Xpress 4" lift
hakukamana is offline
post #2 of 5 Old 08-01-2013, 08:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just make sure you have good tune-up parts including NGK plugs, Belden wires and Napa Premium dizzy cap and rotor. Clean your throttle body and IAC,
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 5 Old 08-01-2013, 11:28 PM Thread Starter
hakukamana
Will do thanks Cruiser
post #4 of 5 Old 08-20-2013, 11:14 AM
BrandonYJReed
What's a "dizzy cap and rotor"?
-1990 YJ, 2.5L, AX-15, lifted, locked, on 35's.
-1999 XJ, 4.0, AW4, lifted 4.5", JK Rubi take offs.
BrandonYJReed is offline
post #5 of 5 Old 08-20-2013, 04:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Distributor cap and rotor.
