ignition problem, out of ideas - JeepForum.com
post #1 of 14 Old 08-11-2012, 07:31 PM Thread Starter
87manche17
1987 MJ Comanche
I have a 87 MJ that just underwent a motor change, it started and ran fine with the old engine, now it will crank but wont kick over. Ive changed my CPS, coil, module. I really dont know what else it could be, could my distributor be bad? Or could it be something I havent thought of.
87manche17 is offline
post #2 of 14 Old 08-11-2012, 07:38 PM
BryceBrown
1987 XJ Cherokee
What all have you done it can be a number of things the pigtail end of your crank position sensor could be the problem as well just like the sensor itself follow the basic steps first check make sure you get fuel once you know your getting fuel check to make sure if your getting spark start at the plug wire the d trick where you have your buddy crank it over and you have a screwdriver in the end of the plug wire and trace it that way all the way to your distributor if that doesnt work let me know it could be fuel pressure but mostlikley its ignition or check your ignition controll module
BryceBrown is offline
post #3 of 14 Old 08-11-2012, 07:47 PM Thread Starter
87manche17
1987 MJ Comanche
its odd because im getting a good strong spark from my coil, but from the distributor cap its self I will get maybe one spark every once in a blue moon.I also checked the CPS its fine. So do I need a distributor?
post #4 of 14 Old 08-11-2012, 11:49 PM
BryceBrown
1987 XJ Cherokee
If you have replaced your distributor cap and rotor then yes if you have then yes its your distributor but also i know those rotars where they are placed is a horrble spot and get condensation in them and make the.points go bad but if its not that then yes you will need a distributor
post #5 of 14 Old 08-12-2012, 06:02 AM Thread Starter
87manche17
1987 MJ Comanche
Ok thanks
post #6 of 14 Old 08-13-2012, 12:09 AM
Rican142
Im havin the same exact problem, try checking ur stator, its a 30 dollar part, its within the shaft of the distributor im not quite sure as how to check it though
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #7 of 14 Old 08-16-2012, 06:34 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Unfortunately, that $30 part has absolutely nothing to do with ignition and only helps time the injectors sequentially. A Renix will run with the stator unplugged.
cruiser54 is offline
post #8 of 14 Old 08-18-2012, 04:23 PM
Rican142
Oh ok
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 14 Old 08-18-2012, 09:41 PM Thread Starter
87manche17
1987 MJ Comanche
Ive pretty much have an all new ignition system, but it still wants to keep up with the same problems. Would the entire distributor itslef cause it not to spark.
post #10 of 14 Old 08-19-2012, 05:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you have spark from the coil wire to the cap, all the distributor does is DISTRIBUTE the fire through the center of the cap, out the rotor, to the terminals inside the cap, and out the wires to the plugs.
post #11 of 14 Old 08-19-2012, 07:08 AM Thread Starter
87manche17
1987 MJ Comanche
It doesnt fire at the plugs, but I know I've got voltage going into the distributor, which is really wierd.
post #12 of 14 Old 08-19-2012, 11:53 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Must be weak voltage if it can't jump from the tip of a rotor to a dizzy cap terminal.
post #13 of 14 Old 08-19-2012, 05:25 PM Thread Starter
87manche17
1987 MJ Comanche
How would I fix that? Would the ECM have any thing to do with it? I have verified it is sending about 12 volts to the cap.
post #14 of 14 Old 08-19-2012, 06:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
12? Where? The voltage to the center of the dizzy cap from the coil is in the tens of thousands of volts.
Ignition problem, please help msgvas61 XJ Cherokee Technical Forum 4 02-03-2012 12:50 PM
Ignition problem, battery, or other electrical problem?... Kasia XJ Cherokee Technical Forum 9 09-24-2011 12:09 AM
Ignition problem BeepTheJeep XJ/MJ Cherokee Non-Technical Forum 1 05-22-2010 05:59 AM
XJ Ignition Problem bryanj23 XJ Cherokee Technical Forum 13 01-18-2007 03:57 PM
Ignition Problem cybrjoe XJ Cherokee Technical Forum 7 10-21-2002 11:41 AM
