ignition module causing spark issue - JeepForum.com
post #1 of 6 Old 08-04-2012, 05:18 PM Thread Starter
87manche17
1987 MJ Comanche
My 87 Comanche is having a issue with the ignition the motor will crank, but I have no spark. Ive already replaced my CPS, Distributor, wires, coil pack, plugs. I have also checked my grounds, I think my ignition module, witch sits under the coil pack, is shot. am I right or could it be something I haven't thought of, I would really appreciate any help.
87manche17 is offline
post #2 of 6 Old 08-06-2012, 06:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this then:
Renix Jeep ICU/Coil contact refreshing
The contacts between the coil and the ICU on your Renix Jeep can become corroded and loose causing a complete or intermittent no-start condition. I recommend the following procedure as a maintenance precaution to insure this is eliminated as a possible cause now and in the future.
The coil is attached to the ICU by two T20 Torx bolts. Remove these two bolts and lift the coil up off the ICU. You will see 2 pins and 2 sets of contacts. Clean both the pins and springy contact pieces with a good electronics cleaner.
Squeeze the springy contacts closer together with some needlenose pliers. Apply some dielectric grease to the contacts and bolt the coil back on to the ICU.
While you’re right there unplug the connectors from the ICU and inspect the pins in the harness connector. Make sure the pins are not retracted into the connector. Spray out the connector and the receptacle of the ICU with the same good electronics cleaner you used earlier. Apply dielectric grease to the connectors and plug them back in.
I feel this procedure should be performed at least once in the lifetime of a Renix Jeep.
Revised 11-29-2011
cruiser54 is offline
post #3 of 6 Old 08-18-2012, 03:56 PM
DonBC
1989 MJ Comanche
I would try the cleaning process as mentioned. I had the same problem about 3 months ago and after following test routines on the components that could affect spark I came to the conclusion that it probably was the ICM. They are a little pricey and I was reluctant to spend the money if that wasn't the problem so I picked one up at a salvage yard and that solved the problem.
DonBC is offline
post #4 of 6 Old 08-18-2012, 06:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
R*C*B*R*C = Refresh* Connections*Before*Replacing*Components
post #5 of 6 Old 03-26-2014, 07:46 PM
vjsimone
Junior Member
2008 XK Commander
Comanche - No Spark
OK 87manche17 - What happened??
Thanks Cruiser54 for your post, my 88 MJ, IL6 had a no spark situation. MJ sat up a few months. Cleaned the connectors under the coil, and she started right up.
Vincent
99 XJ Limited, 95 YJ, 93 ZJ Grand Wagoneer, 88 Grand Wagoneer,
88 MJ Comanche, 61 Willys Wagon
Last edited by vjsimone; 03-28-2014 at 07:30 AM. Reason: Update on repair issue after reading post.
vjsimone is offline
post #6 of 6 Old 04-03-2014, 09:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Woohoo!!
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
Where is the Ignition Control Module??? legendofgotham XJ Cherokee Technical Forum 11 10-09-2015 01:27 PM
Ignition control module fathersumruld XJ Cherokee Technical Forum 3 07-13-2011 09:26 AM
ignition module questions extreme69 XJ Cherokee Technical Forum 9 05-02-2008 04:56 PM
ignition control module? Ex-Jay XJ Cherokee Technical Forum 5 03-26-2006 10:04 AM
Ignition Module Dvs_Lance XJ Cherokee Technical Forum 9 03-17-2005 10:05 AM
