Idle speed too high - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Idle speed too high
Poison Spyder Dana 44 Bombshells Are BACK!!Poison Spyder RockBrawler II Rear Bumper with Tire CarrierPoison Spyder from CCOR!
Unread 10-25-2006, 12:21 AM   #1
500$comanche
Idle speed too high
Posted this in the XJ forum due to # of potential responses, but wanted to post it in its proper forum too! Thanks!
Hey everyone, my first night/time on the board. I figured I would get more responses in the xj forum, and after all aren't we all bretheren in jeepdom? I have an 89 comanche with the 4.0L (paid $500 for it 2 months ago). When I first had it the engine idled at about 800RPM once warmed up. Now it idles at about 1200RPM and fluctuates up and down a tiny bit (between 1100-1300RPM). Not a huge deal, but I was just wondering what the cause might be. Do I need a new throttle positioning sensor? The temperature is about 30 deg less now, but I didn't think that was the root of the problem. Thanks for any info you can provide.
500$comanche is offline   Reply With Quote
Unread 10-27-2006, 05:45 AM   #2
75SV1
The is an AIC (??) in the older TBs I think. It might need cleaned and/or replaced. This might cause high idle or the engine to race. Also look for vacum leaks.
Tom
75SV1 is offline   Reply With Quote
