I just saw in a junkyard...... - JeepForum.com
post #1 of 10 Old 04-23-2008, 01:23 PM Thread Starter
JPK
2005 WK
.....while searching for parts for my XJ, a 1986 Comanche XLS long bed 4x4. Auto tranny with what looks like a V6 under the hood. This MJ obviously had a factory stock interior with buckets and a console. Did this model have a particularly special front or rear axle?
JPK is offline
post #2 of 10 Old 04-23-2008, 01:51 PM
Pete M
1988 MJ Comanche
The front axle is nothing special. Just a Dana 30. If it's a Metric tonne/Big ton package, then it'll have the cool AMC-20 rear end.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 10 Old 04-23-2008, 05:36 PM Thread Starter
JPK
2005 WK
Re: JY MJ
Jeep on!
--Pete
How can you tell if it had that option package?
JPK is offline
post #4 of 10 Old 04-23-2008, 06:12 PM
Pete M
1988 MJ Comanche
The rear leafs will have 5 total leafs (be wary of regular packs with add-a-leafs stuck in there) and the rear diff cover will be spherical like a basketball.
My email:
Pete M is offline
post #5 of 10 Old 04-23-2008, 08:39 PM Thread Starter
JPK
2005 WK
Re: MJ
I'll try to get back out there tomorrow to have another look. I might take my camera with me to take a few pictures.
I think I do recall that there wasn't a drain plug on the rear housing of the diff.
JPK is offline
post #6 of 10 Old 04-23-2008, 08:45 PM Thread Starter
JPK
2005 WK
I just noticed in the MJ Spec section
That this particular truck is one from the first year AMC made the Comanche. Interesting.
JPK is offline
post #7 of 10 Old 04-26-2008, 07:18 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Just take pics of the whole truck.
Inside, outside, and axle.
88XJSport is offline
post #8 of 10 Old 05-19-2008, 03:16 PM
VZEHLER
VZEHLER's Avatar
FYI, later metric tonne MJ's had a Dana 44 in the rear. I believe 88 and up.
VZEHLER is offline
post #9 of 10 Old 06-23-2008, 08:39 AM
wahoosteeler
1988 MJ Comanche
JPK, did you ever get back out to see under this truck?
Pete, if I am correct, in 86 if it had an AMC20 rear it automatically had the m/t springs.
JPK, I am desperately looking for MT springs, so even if you have not gotten back out there, can you give me the info on the yard? I assume you are not interested these for yourself. Thanks for any help.
wahoosteeler is offline
post #10 of 10 Old 06-23-2008, 11:03 AM
Pete M
1988 MJ Comanche
Yes, as far as I can tell, the AMC-20 only came with the MT package. Later years could get the Dana 44 as part of the trailer prep package and that would be sans MT leafs.
Jeep on!
--Pete
My email:
Pete M is offline
Went to the junkyard... USMC_XJ XJ Cherokee Technical Forum 27 09-20-2009 11:13 AM
Going to the junkyard soon. willcherokeexj XJ Cherokee Technical Forum 2 08-26-2009 03:43 PM
What to look for in junkyard XJs Jory XJ/MJ Cherokee Non-Technical Forum 14 11-19-2008 07:37 PM
junkyard!!! bigern26 XJ Cherokee Technical Forum 9 05-30-2008 08:41 PM
junkyard run 89XJ74 XJ Cherokee Technical Forum 9 04-25-2008 06:25 AM
