I got a miss issue - JeepForum.com
post #1 of 5 Old 09-24-2013, 07:27 PM Thread Starter
Crash7500
1987 MJ Comanche
I got a miss issue
I have a miss issue. It is only once in awhile. I have changed the plugs wires cap and button and still does it. It does it when you first start it and take off then it smooths out and then it will miss like one time just every once in awhile some days more than others. It is a 2.5L. Anyone have any ideas. Thanks. Some one took the cat converter off it and the O2 sensor is just hanging under the truck, would that do it?
Crash7500 is offline
post #2 of 5 Old 09-28-2013, 06:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Remove the braided ground strap from the firewall. Scrape the paint from under it and clean it's terminal. Reinstall tightly.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 5 Old 12-29-2013, 02:58 PM Thread Starter
Crash7500
1987 MJ Comanche
I did the ground wire deal, all intake bolts seem to be tight. Would you think it could be the coil
post #4 of 5 Old 12-29-2013, 03:00 PM Thread Starter
Crash7500
1987 MJ Comanche
When it does it. It seems to be like under a load right befor it will down shift and if you floor board it it picks right up and goes
post #5 of 5 Old 12-29-2013, 03:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Click on my link below and do posts 1, 3, and 4.
