How to repair door hinge play. - JeepForum.com
post #1 of 3 Old 11-16-2012, 09:41 AM Thread Starter
FASTNASH
1988 MJ Comanche
I would like to know, what to do for play in door hinges, because mopar does offer anything. I have idea to put bigger pin or bolt in hinge. We are middle of prep for paint, would like to fix before paint on it. Thanks Darrin
FASTNASH is offline
post #2 of 3 Old 11-17-2012, 07:45 PM
Pete M
1988 MJ Comanche
is it due to play in the pin? or rust rotting out the steel on the body that the hinge is attached to?
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 3 Old 11-17-2012, 08:08 PM Thread Starter
FASTNASH
1988 MJ Comanche
It is due from the pin in the hinge and was wondering if anyone ever found better pin from the stock one, I took stock replacement pins and still loose, I looked on dorman line product website and found a pin dia is close to mind and little oversized, when it comes in I try it see what happens.
FASTNASH is offline
