How to lift my Comanche - Page 2 - JeepForum.com
post #16 of 20 Old 10-04-2011, 09:32 PM
jsc7002
1966 CJ5
it will work but it is an add-a-leaf which tend to be pretty stiff since its that one leaf spring that gives you your lift and they tend to wear down and you lose a little bit of your lift.
jsc7002 is offline
post #17 of 20 Old 10-05-2011, 08:59 AM
Jafxod
Thank you!. Im guessing If i want a smidge more lift in the front I could always do a 1" spacer too correct?
Jafxod is offline
post #18 of 20 Old 10-05-2011, 09:03 AM
jsc7002
1966 CJ5
Yes, you could also add a spacer but be careful bc if you go high enough you'll need longer lca's.
jsc7002 is offline
post #19 of 20 Old 10-05-2011, 09:15 PM
Garvin
1986 MJ Comanche
Rear SOA will net you ~5.5" of lift. This all depends on the perches though (axle diameter + 2x perch height). If you have the extra cash, go with the Hell Creek rear full packs over the AAL.
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #20 of 20 Old 10-28-2011, 10:20 AM
carnuck
1984 J-Series Truck
SOA rear with used 6 1/2" TJ lift coils (gained 5") and extended lower arms with YJ brake hoses and a Superlift? adjustable tracbar. Sitting on 33/9.50/15 (in the rear. Took the pic before I put the new fronts on)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
cherokee , comanche , how to , jeep , lift
help me lift my comanche! adamhall2942 MJ Comanche Technical Forum 1 04-14-2011 09:51 PM
Comanche Lift help blueridgexj98 MJ Comanche Technical Forum 8 01-15-2011 07:26 AM
86 comanche 6" lift jebnmikki MJ Comanche Technical Forum 10 07-08-2010 10:39 AM
Just got a Comanche and see they already did a SOA lift Please look. kosonen04 MJ Comanche Technical Forum 20 12-08-2007 09:55 PM
88 Comanche Lift 88MJ4x4 XJ Cherokee Technical Forum 20 01-23-2005 04:59 AM
