How to lift my Comanche - JeepForum.com
post #1 of 20 Old 07-13-2011, 07:48 PM Thread Starter
MakeWave
1991 MJ Comanche
I have a 1991 Comanche and I was wondering what I need to lift my truck 2 or 3"? For around $200, I want to do shackles in the rear and coil spacers in the front but I cannot find anything online! Any help will be greatly appreciated
MakeWave is offline
post #2 of 20 Old 07-14-2011, 08:29 AM
Garvin
1986 MJ Comanche
The only shackle out there that will give you a true 2-3" lift is the IronMan4x4 ones, I'm running them on the back of my Jeep right now and they're beefy as hell. For the front, search for Cherokee 2" coil spacer (I would not go any higher than 2" on the spacers for safety reasons). There are MANY companies out there that make the spacers.
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #3 of 20 Old 07-18-2011, 06:11 PM
NYTrailrider
1988 MJ Comanche
Why is this the only one? What's so special about them?
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline
post #4 of 20 Old 07-18-2011, 06:45 PM
Garvin
1986 MJ Comanche
The issue is every other shackle I've seen was made for the Cherokee. The Comanche shackle is ~1" longer than the Cherokee shackle. You would need to find a 2.5" shackle for a Cherokee to get the 2" for the Comanche (every 2" the shackle is longer than stock gives you 1" of lift). The IronMan4x4 shackles I have is set at a hair under 4" longer than stock Comanche shackles when set to the smallest setting, which yields 2" of lift for the Comanche.
If you want the true adjustment from 2-3" for the rear, IromMan4x4 makes the only true adjustable shackle. Every other shackle out there that is "adjustable" is just another set of holes drilled to give you two fixed lengths. The IronMan4x4 shackles has a screw type adjustment (like on the adjustable control arms) letting you fine tune to the ride height that you want.
...RIP...
Garvin is offline
post #5 of 20 Old 07-18-2011, 07:20 PM
mj40
1989 MJ Comanche
coil spacer or coils from a newer v8 grand cherokee..local wrecker should be able to help.. i've heard ford f150 2wd coils work, but never tried them...
new front flex lines for brakes-95 newer yj flex line 3-4 inches longer
shocks- cheap--- mr gasket 3 or 4 inch shock extentions..
mj40 is offline
post #6 of 20 Old 07-20-2011, 01:24 PM Thread Starter
MakeWave
1991 MJ Comanche
I was thinking about putting these in the rear
http://item.mobileweb.ebay.com/viewi...id=65478463072
MakeWave is offline
post #7 of 20 Old 07-30-2011, 10:21 PM
Slagelf
1986 MJ Comanche
Front coils from a dakota will do a 3 in lift in front and take a Cherokee leaf pack and mate it with your mj leaf to make a lift or do axle flip will do 4in
Slagelf is offline
post #8 of 20 Old 08-01-2011, 12:16 PM
Garvin
1986 MJ Comanche
The SOA will net around 5.5" of lift, not 4".
...RIP...
Garvin is offline
post #9 of 20 Old 08-05-2011, 08:22 AM
dkroll
1988 MJ Comanche
I just finished a soa on the back of mine and I believe it already had hefty leafs on it. It seemed to raise it 8-8 1/2 inches total. I now am looking into a long arm for the front. The problem is that I am doing a frame up and don't have the weight of the engine, tranny, transfer case or anything on it to determine what I really need. I guess I will wait until I finish painting the engine compartment, install the engine,ect. to see what it will take to even it out.????
dkroll is offline
post #10 of 20 Old 08-05-2011, 05:30 PM
Garvin
1986 MJ Comanche
8-8.5 sounds a bit off. The springs don't have much to do with the lift, it's the axle tube diameter plus 2x the tube to spring mounting distance. This is around 5.5" with a D35 and D44. Measure from the center of the axle to the bottom of the flare. 26" distance is 6.5" (keep in mind that the truck has a 2" rake so to level it out, the front needs to be around 8.5"). SOA in the rear and the IronMan4x4 shackles all the way in netted me 6.5" lift, for comparison.
For the front springs, I love the Rusty's 8.5" lift coils. Ran them on my old Cherokee for about two years then slapped them on my Comanche. Even being about 4 years old now, they still measure 8.5" lift (center of hub to bottom of flare) in the front. That's even with the extra weight of the Chevy 350, custom 1/4" front cross member and winch added. For the long arms, that is a lot to do with personal preference and what you plan on doing with the Jeep.
I chose to build my own true 3-link setup since nothing on the market satisfied my needs. The most common, and generally the cheaper setup, is the y-link setup (or radius arm, all matters who you talk to). I had the first gen Rusty's setup on my old Cherokee (rubber bushings all around) and it flexed great for a "4" link, drove great on the street also. If I were to go with another off the shelf y-link setup, I would do T&T Customs due to the fact of the beefy belly pan and the frame end joints are offset up to let you slide off obstacles easier. RockKrawler has a 3 link that is beefy but the frame side separation wasn't enough for my needs and I don't like how it mounts below the frame (again, personal preference on that part). I'll leave it at that before I start going into geometry and all that fun stuff of suspension systems.
...RIP...
Garvin is offline
post #11 of 20 Old 09-20-2011, 12:45 PM Thread Starter
MakeWave
1991 MJ Comanche
Thanks everyone for all the help! Iam thinking about the grand Cherokee coils for the front but what kind of leaf springs will I need in the rear to lift the truck 3 inches? And will I need anything else?
MakeWave is offline
post #12 of 20 Old 09-21-2011, 11:10 AM
Craft95ZJ
1986 MJ Comanche
I'm running XJ 2" shackles and MJ 2" add-a-leafs. Which gave me 3" on the rear.
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #13 of 20 Old 09-21-2011, 08:45 PM Thread Starter
MakeWave
1991 MJ Comanche
I just seen a Comanche with the spring over axel and the guy had 2inch blocks underneath the springs and it's about a 5 1/2 inch lift so if I just do SOA what hight will my truck be in the rear! And if u guys have any suggestions as to what I should do for a 3 inch lift just put it out there I wanna do this soon...
MakeWave is offline
post #14 of 20 Old 09-22-2011, 06:16 AM Thread Starter
MakeWave
1991 MJ Comanche
I just found this lift kit. But will it reall work for a true 3" lift?
http://www.jcwhitney.com/suspension-...equestid=69119
MakeWave is offline
post #15 of 20 Old 10-02-2011, 06:56 PM
Jafxod
Wondering the same thing. Anyone have experiance with this?
Jafxod is offline
cherokee , comanche , how to , jeep , lift
help me lift my comanche! adamhall2942 MJ Comanche Technical Forum 1 04-14-2011 09:51 PM
Comanche Lift help blueridgexj98 MJ Comanche Technical Forum 8 01-15-2011 07:26 AM
86 comanche 6" lift jebnmikki MJ Comanche Technical Forum 10 07-08-2010 10:39 AM
Just got a Comanche and see they already did a SOA lift Please look. kosonen04 MJ Comanche Technical Forum 20 12-08-2007 09:55 PM
88 Comanche Lift 88MJ4x4 XJ Cherokee Technical Forum 20 01-23-2005 04:59 AM
