How do you fix an expansion plug leak? - JeepForum.com
post #1 of 3 Old 06-22-2005, 10:27 AM Thread Starter
GDSQDCR
As the title says.
Apparently my expansion plug is leaking on the 4.0. How can I fix it? Can I throw some JBWeld at it or do I need to pull the plug and replace ...
Thanks!
Anthony
90 2wd, 4.0, 5 spd ... staying stock, mostly
GDSQDCR is offline
post #2 of 3 Old 06-25-2005, 05:19 PM
cj7xjmj
cj7xjmj's Avatar
You need to remove the leaking one and replace it with a new one. Some auto parts store sell ones that have a rubber bushing that you compress, to seal up the freeze plug hole. The metal ones, steel, or brass are the better way to go, but you almost need to pull the motor out to do it right in my opinion.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #3 of 3 Old 06-26-2005, 03:01 AM Thread Starter
GDSQDCR
I found a local shop to replace the one on the left side of the motor, under the intake/exhaust manifold for $100. He says all he has to pull in the exhaust pipe from the manifold to the cats.
Anthony
GDSQDCR is offline
Leaking Expansion Bottle zacharyt MJ Comanche Technical Forum 3 07-02-2009 02:54 AM
stiff expansion valve nut ChipsXJ XJ Cherokee Technical Forum 1 07-01-2005 05:46 PM
A/C Expansion Valve SmittysXJ XJ Cherokee Technical Forum 4 06-29-2005 10:14 PM
Expansion reservoir - coolant trashman XJ Cherokee Technical Forum 14 03-06-2005 11:07 PM
overflowing expansion tank rokclimbertx XJ Cherokee Technical Forum 5 09-08-2004 09:35 PM
