How do you burp the cooling system in a 4.0 - JeepForum.com
post #1 of 6 Old 07-07-2005, 10:11 PM Thread Starter
GDSQDCR
I have a 90 4.0. I believe I introduced air into the system while I was changing some parts.
How do I burp the system to get the air out? The only opening I have is the reservoir cap.
Thanks!
Anthony
90 2wd, 4.0, 5 spd ... staying stock, mostly
GDSQDCR is offline
post #2 of 6 Old 07-08-2005, 09:25 AM
MJDriver
MJDriver's Avatar
There are a couple suggestions for this. One is to warm it up with the cap closed, then drive it around with the reservoir cap cracked enough to let out excess pressure. Close it when you are satisfied it has balanced at a good pressure.
I did it the rather stupid way, as I forgot about about built up heat after shut off. I replaced all the hoses, filled it as much as possible with coolant, then let it run for 15 minutes. It seemed fine so I shut it off. That's when it almost blew apart the reservoir with excess coolant and pressure. I used a rag and opened the cap and let it burp out all the excess coolant (a whole lot of it), and used a turkey baster to drain more and bring it back down to a decent level.
The first couple times after that, when I got home I would lightly open the cap and let out the excess pressure. Now it works just fine.
Good luck.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #3 of 6 Old 07-20-2005, 09:24 PM
Tonka
2015 JK Wrangler
I pull the heater hose, at the thermostat, fill through bottle it till coolant is at the top of the thermostat neck, replace hose, top off coolant motor running, bottle cap off
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 6 Old 07-22-2005, 08:18 PM
Ed in North Ga
1989 MJ Comanche
foolproof method->
park jeep with rear end higher than front- that gets the rear of the engine higher than the front.
with jeep off- loosen the temp. sending unit on the rear of the engine block-- looking inside from the front bumper, located right rear of the engine/just right of the valve cover/firewall area/above the intake/exhaust. One wire hookup.
loosen, but dont remove--just a couple of threads holding it in. (removeing causes volcano of coolant).
with the jeep sitting with the rear of the engine higher than the front, that sending unit is now the highest point- the air that gets trapped in the head that no one can ever seem to remove is now sitting right under there-- Fill engine and plastic "piece of junk" coolant bottle with antifreeze goo- start engine and watch for coolant to start leaking from the sending unit hole- shut engine off and tighten it back down when it does flow out.
there be no air in dere no mo.
1989 Jeep MJ- 200,000- 28mpg. If its a Renix, its all good. 1989 XJ (sold) 310,000- 29mpg. Renix. See the pattern?
Ed in North Ga is offline
post #5 of 6 Old 07-22-2005, 09:39 PM
Dana44
ah, the joys of a closed loop cooling system. not very smart
hmm.. i didnt even know air would affect it.
i know when you do like a water pump, or lose water in any way. dont rely on the tank, gotta pop a hose off and fil it manually.
Dana44 is offline
post #6 of 6 Old 07-22-2005, 10:14 PM
Ed in North Ga
1989 MJ Comanche
hehe- the joys? naaaa, I wouldnt even go that far. the "pains" maybe...
ah well- Ive had two- both have gone at least 200,000 with the XJ topping 320,000....both closed systems. One radiator apice...well, one anyway, Im waiting on the MJ to blow its seams.
the "air" that "affects" it, is the wonderfull design of the old 4.0s head...its like a RAID bug trap. Air gets in, and never gets out- it dutifully resists gravity and heads to the front of the engine(since its higher normally anyway) away from the sending unit...excellent design(flaw).. -- some decide that the coolant tank heat/cool/heat cycle will rid the head of its air, some decide to pull hoses and fill to their hearts content. ALOT of people live with it....and wonder why the guage wanders so...must be ghosts.
Ive done it for years(both ways)- I`ll stand by my way. Burrrrrpppppp. No mo air.
Dam coolant tanks are over $30 again..at this rate, i`ll have to convert to the open system in, ohhhhhh....another 75,000 or so....naaaaaaa. I`ll buy a metal tank next go-round.
How to burp open cooling system USMC_XJ XJ Cherokee Technical Forum 2 08-25-2009 08:54 PM
How do you burp you cooling system? bhicks XJ Cherokee Technical Forum 21 04-24-2009 12:34 PM
cannot burp cooling system LUGGNUTT XJ Cherokee Technical Forum 27 01-10-2009 05:08 PM
how to burp cooling system on 89 cherokee eas020223 XJ Cherokee Technical Forum 4 04-27-2005 04:54 PM
Yea so im gonna burp my cooling system b(k)ill94xj XJ Cherokee Technical Forum 6 08-16-2004 01:49 AM
