How This Comanche Look? - JeepForum.com
post #1 of 28 Old 03-29-2010, 10:00 AM Thread Starter
Gnl.Weirdness
Any thoughts? Think she'd be a good DD while I work on the Cherokee?
1988 Jeep Comanche, Rust Free!
Price could prolly be negotiated down a bit. Looks to be in good condition.
Gnl.Weirdness is offline
post #2 of 28 Old 03-29-2010, 10:01 AM
Mark4883
High miles but it looks like its in great shape
Mark4883 is offline
post #3 of 28 Old 03-29-2010, 10:02 AM
77j20
1977 J-Series Truck
Wow that is a clean Manche. Especially for the east coast. Id say talk him down and grab it up. Even if it is only 2wd I believe they are easily converted to 4wd if the need arises.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
post #4 of 28 Old 03-29-2010, 10:04 AM Thread Starter
Gnl.Weirdness
yeh, it would arise eventually. I just need something I can pay for with a loan, that's rust free. I can worry about doing all the work later.
post #5 of 28 Old 03-29-2010, 10:58 AM
Pete M
1988 MJ Comanche
pull up the edges of the carpet and check for moisture and rust. No Comanche is immune to floor rot.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #6 of 28 Old 03-29-2010, 11:18 AM Thread Starter
Gnl.Weirdness
floor rot is ok, it's frame rot that scares me
post #7 of 28 Old 03-29-2010, 12:01 PM
Pete M
1988 MJ Comanche
floor rot leads to frame rot.
My email:
Pete M is offline
post #8 of 28 Old 03-29-2010, 12:02 PM Thread Starter
Gnl.Weirdness
Doubt the rust would be too bad given it came from TN.
Anyone know what tranny it would have? My first job would def be to change out and do 4x4 maybe with an AW4 behind the 4l
Anyone know if that can be done? Is it bolt on, or would it require fab work?
post #9 of 28 Old 03-29-2010, 12:02 PM Thread Starter
Gnl.Weirdness
Oh jeezus, you had a bad case. Where you able to repair it?
post #10 of 28 Old 03-29-2010, 01:49 PM
Pete M
1988 MJ Comanche
that particular truck is still a work in progress. there are a dozen ways for water to leak under the carpet, and once it's there, this is inevitable.
Swapping to a 4.0L/auto/4wd is pretty much a bolt-in thing, but you'll need to change EVERYTHING about the truck. But all you really need is a decent running XJ as a donor.
My email:
Pete M is offline
post #11 of 28 Old 03-29-2010, 01:52 PM Thread Starter
Gnl.Weirdness
Indeed, and I am hesitant to do that, cus I love the idea of a 4-5speed, but the aw4 is freaking bullet proof haha.
post #12 of 28 Old 03-29-2010, 01:55 PM
rubidriver
Its a 2wd.... I would close the page down right after seeing that if I were you.. I know I did.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #13 of 28 Old 03-29-2010, 03:13 PM
Pete M
1988 MJ Comanche
huh? a 4wd conversion is a bolt-in affair with the right parts. There's no good reason to skip a pristine 2wd body just because 4wd is desired.
But a switch to an AW-4 is a complicated procedure since the trans is computer controlled.
It's a 2.5L. Pretty much everything is bulletproof behind it.
My email:
Pete M is offline
post #14 of 28 Old 03-29-2010, 08:42 PM Thread Starter
Gnl.Weirdness
yeh I def am not turning it down because it's a 2.5 or because it's a 2wd lol. These things are super easy to convert if you can find the parts, and if it's truly rust free, $1500 is a dealio in my book.
post #15 of 28 Old 03-31-2010, 01:50 PM Thread Starter
Gnl.Weirdness
got pics, she looks CLEAN. Will post them up when I get home for advice.
I wanna try and pick her up next week :: )
Looking at getting a comanche, anything I should know? cmetcjr MJ Comanche Technical Forum 2 07-17-2008 08:53 AM
Looking for a ISA for a 87 comanche franks67gto MJ Comanche Technical Forum 2 12-23-2006 09:09 PM
89' comanche keats MJ Comanche Technical Forum 10 11-18-2006 09:48 AM
Just got a Comanche Lewis MJ Comanche Technical Forum 3 02-25-2005 04:07 PM
Comanche Bed BirchBomber XJ Cherokee Technical Forum 4 12-21-2004 02:43 PM
