hitch - JeepForum.com
post #1 of 10 Old 05-20-2013, 10:54 AM Thread Starter
caddynut
hitch
what hitches will interchange or should I just build a rear bumper with one in it thanks
caddynut is offline
post #2 of 10 Old 05-23-2013, 10:17 PM
ftpiercecracker
1990 MJ Comanche
Comanche hitches are unique, sadly. Either you buy a comanche specific hitch or build your own bumper.
ftpiercecracker is offline
post #3 of 10 Old 01-07-2014, 04:15 AM
SOWEGA TJ
a TJ one wont work?
SOWEGA TJ is offline
post #4 of 10 Old 01-07-2014, 05:22 PM
87MJTim
1987 MJ Comanche
Saddly, no.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #5 of 10 Old 01-09-2014, 06:59 AM
dkroll
1988 MJ Comanche
I had U-Haul install one on mine, class three- works/looks great!
Doug
dkroll is offline
post #6 of 10 Old 01-09-2014, 07:28 AM
87MJTim
1987 MJ Comanche
How long ago was that?
Uhaul hasnt made the MJ hitch in years.
Tim
87MJTim is offline
post #7 of 10 Old 01-10-2014, 06:36 AM
dkroll
1988 MJ Comanche
True, this was over 12 years ago. Don't know if they still do it or not.
Nevertheless, that is where I got mine. fyi
Doug
dkroll is offline
post #8 of 10 Old 01-10-2014, 07:28 AM
87MJTim
1987 MJ Comanche
"Oow, you lucky b@st@rd!" Monty Python, Life of Brian.
Reese, DrawTite and Uhaul have not made then for 10+ yrs. You must have gotten one of the last.
There were less than 200k MJs build and the youngest is 22 yrs old. So the big boys arent going to make them unless the demand is there (not).
The rear of the MJ is diff from the XJ, so the XJ receivers wont fit.
To the OP, your best bet is to search jy's. On Comancheclub, there are several threads about rear receiver hitches. http://comancheclub.com/topic/26626-...-5?hl=receiver One member has drawn up the plans for the mounting bracket. You will need to find a cross piece to weld to them. I took the plans to welding/fabricator and was quoted at $140 for the brackets.
There a number of custum bumper builders advertising on JF and CC for MJ bumpers. You may look at some of those.
Good luck
Tim
87MJTim is offline
post #9 of 10 Old 01-10-2014, 06:40 PM
dkroll
1988 MJ Comanche
I would gladly trade a shortbed original roll bar for it!
That would be way cool
Doug
dkroll is offline
post #10 of 10 Old 01-10-2014, 07:35 PM Thread Starter
caddynut
thanks all I took a s-10 4x4 universal and made it fit
caddynut is offline
